At the top of the Acad window, in the menu, click on POINTS. then select POINT SETTINGS then click on the UPDATE tab. Check the "allow points to be moved" box.
MJ, sometimes the client decides to use a deed call as the basis of bearings on a project, then you have to move your points and maybe rotate them to fit. You'd be surprised how often this happens. Plus a lot of companies run their field work on assumed coordinates and then move it to state plane or deed. I know it's better if you have all of this before hand, but it very seldom works that way. Especially if an engineer or architect is driving the operation.
