Author Topic: dimension lisp works in 2000 but not in 2004  (Read 6237 times)
danny
« on: September 24, 2004, 05:20:53 PM »
I have a bunch of dimension routines where you can enter the command, or click on icon tool bar, to draw a dimension or leader w/ notes to a desired scale.  Its working fine in ACAD 2000i but I cannot get it to work in ACAD 2004. :?:
Here are some examples of the lisp.
;Sets Text leader to Full scale
(defun c:diml1 ()
 (setq oldcmdecho (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (setq lyr(tblsearch "layer" "a-anno-text"))
 (if(= lyr nil)
 (command "layer" "m" "a-anno-text" "c" "r" "" "")))
 (command "clayer" "a-anno-text")
  (command "units" "4" "" "" "" "" "")
  (setq dstl(tblsearch "dimstyle" "l1"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/l1.dwg" ^c)))
  (command "dimstyle" "r" "l1")
  (setvar "cmdecho" oldcmdecho)
  (command "_qleader")
;Sets dimension to Full scale
(defun c:dimm1 ()
 (setq lyr(tblsearch "layer" "a-anno-dims"))
 (if(= lyr nil)
 (command "layer" "m" "a-anno-dims" "c" "g" "" "")))
 (command "clayer" "a-anno-dims")
  (setq dstl(tblsearch "dimstyle" "m1"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/m1.dwg" ^c)))
  (command "dimstyle" "r" "m1")
  (command "dimlinear")
;Sets Text leader to 6" scale (half size)
(defun c:diml2 ()
 (if(= lyr nil)
  (setq dstl(tblsearch "dimstyle" "l2"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/l2.dwg" ^c)))
  (command "dimstyle" "r" "l2")
;Sets dimension to 6" scale (half size)
(defun c:dimm2 ()
 (if(= lyr nil)
  (setq dstl(tblsearch "dimstyle" "m2"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/m2.dwg" ^c)))
  (command "dimstyle" "r" "m2")
;Sets Text leader to 3" scale
(defun c:diml4 ()
 (if(= lyr nil)
  (setq dstl(tblsearch "dimstyle" "l4"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/l4.dwg" ^c)))
  (command "dimstyle" "r" "l4")
;Sets dimension to 3" scale
(defun c:dimm4 ()
 (if(= lyr nil)
  (setq dstl(tblsearch "dimstyle" "m4"))
  (if(= dstl nil)
  (command "insert" "c:/cadmenu/blocks/m4.dwg" ^c)))
  (command "dimstyle" "r" "m4")
any help is appreciated..
  • Custom Title
« Reply #1 on: September 24, 2004, 07:04:36 PM »
You might want to try this gem that CAB wrote.
http://theswamp.org/phpBB2/viewtopic.php?t=1392
or not ........... !!  :D
I just noticed that you are insterting blocks as well. sorry  :roll:
  • Custom Title
« Reply #2 on: September 24, 2004, 07:08:12 PM »
Do you get any error messages? Did you step thought each of the "commands" in one of the functions?
Anonymous
« Reply #3 on: September 24, 2004, 07:48:18 PM »
this is the error message that I get in ACAD 2004
Command: diml1
Unknown command "LAYER".  Press F1 for help.
Unknown command "M".  Press F1 for help.
Unknown command "A-ANNO-TEXT".  Press F1 for help.
Unknown command "C".  Press F1 for help.
Unknown command "R".  Press F1 for help.
Unknown command "DIML1".  Press F1 for help.
Cannot set CLAYER to that value.
 Function cancelled
; error: An error has occurred inside the *error* functionAutoCAD variable
setting rejected: "blipmode" nil
*Invalid*
-this is what I get in ACAD 2000:
Command: diml1 _qleader
Specify first leader point, or [Settings] <Settings>:
Specify next point:
Specify next point:
Specify text width <0">:
Enter first line of annotation text <Mtext>:
I installed the lisp the same way as I did in 2000.
I go to options, file, support, and add a path to a folder called cadmenu.
the cadmenu folder,located on my c: drive, contains 4 subfolders (blocks, icons, menu, temp).  then in CAD I do a menuload, browse to the cadmenu/menu and load the .mns file.
danny
« Reply #4 on: September 24, 2004, 07:51:06 PM »
sorry, the last message is mine, forgot to log in..
I'll check out Cab routine and see if it works for me..
  • Custom Title
« Reply #5 on: September 24, 2004, 09:07:13 PM »
try this one;
(defun c:dimm1 (/ oldcmdecho return)
 ; search for existing layer
  (if (not (tblsearch "layer" "a-anno-dims"))
 ; if layer doesn't exist then create it
 ; else
 ; if it does then set it current
    (setvar 'clayer "a-anno-dims")
    ) ; if
 ; set units to Architectural
  (setvar 'lunits 4)
 ; search for existing dim style
  (if (not (tblsearch "dimstyle" "m1"))
 ; if not found insert a block that contains it
      (command "insert" "c:/m1.dwg" "0,0" "" "" "")
 ; then set it current
      ) ; progn
 ;else
 ; if it does exist then just set it current
    ) ; if
 ; re-set variable
 ; start dimlinear command
(command "_.dimlinear")
  • Custom Title
« Reply #6 on: September 24, 2004, 09:15:47 PM »
Here is your code with comments.
(defun c:dimm1 (/ oldcmdecho); localize your variables
 (if(= lyr nil)
 (progn ; you don't need this since you only have one expression
 (command "layer" "m" "a-anno-dims" "c" "g" "" ""))); <- if ends here
 (command "clayer" "a-anno-dims");<-- don't need this when using "layer" "m"
    ; use lunit variable instead of units command
  (if(= dstl nil)
    ; I think the problem is not enough arguments
    ; in the "insert" command
  (command "insert" "c:/m1.dwg"))); <- if ends here
danny
« Reply #7 on: September 24, 2004, 09:31:51 PM »
mark, still doesn't work. i get this error message
Command: dimm1
Unknown command "A-ANNO-DIMS".  Press F1 for help.
Unknown command "G".  Press F1 for help.
Unknown command "DIMM1".  Press F1 for help.
"m1.dwg": Can't find file in search path:
  C:\Documents and Settings\derek\My Documents\ (current directory)
  C:\DOCUMENTS AND SETTINGS\DEREK\APPLICATION DATA\AUTODESK\AUTODESK
ARCHITECTURAL DESKTOP 2004\R16.0\ENU\SUPPORT\
  C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 2004\SUPPORT\
  C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 2004\FONTS\
  C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 2004\HELP\
  C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 2004\EXPRESS\
  C:\PROGRAM FILES\AUTODESK ARCHITECTURAL DESKTOP 2004\SUPPORT\COLOR\
  C:\DOCUMENTS AND SETTINGS\ALL USERS\APPLICATION DATA\AUTODESK\AUTODESK
ARCHITECTURAL DESKTOP 2004\R16.0\ENU\LAYERS\
  C:\2004CADMENU\MENU\
  C:\2004cadmenu\text\
  C:\2004cadmenu\blocks\
  C:\Program Files\Autodesk Architectural Desktop 2004\
*Invalid*
 Function cancelled
I think I have to upload my cadmenu folder so that we can take a look at the intire setup.  How do I upload this folder?
  • Custom Title
« Reply #8 on: September 24, 2004, 09:41:54 PM »
try changing the path to your setup.
hint:
danny
« Reply #9 on: September 24, 2004, 10:10:32 PM »
"m1.dwg" is located in "C:\2004cadmenu\blocks\"
the error message shows that it searched this folder?
« Reply #10 on: September 24, 2004, 10:13:59 PM »
Quote from: danny
Command: dimm1
Looks to me like the layer command may have been redefined.
try this.
(defun c:diml1 ()
 (if(= lyr nil)
 (command ".-layer" "m" "a-anno-text" "c" "r" "" "")))
 (command ".clayer" "a-anno-text")
  (command ".units" "4" "" "" "" "" "")
  (if(= dstl nil)
  (command ".insert" "c:/cadmenu/blocks/l1.dwg" ^c)))
  (command ".dimstyle" "r" "l1")
  (command "_.qleader")
danny
« Reply #11 on: September 24, 2004, 10:28:57 PM »
thanks CAB, that worked..
What does the "." in front of ".layer" do?
« Reply #12 on: September 24, 2004, 10:39:13 PM »
The . tells acad to use the built-in command and not one that has be redefined.
In the case of the layer command the - tells acad to use the command line version of the
command and not the dialog box version.
danny
« Reply #13 on: September 24, 2004, 10:53:53 PM »
cool..
I have one more problem though. I just updated my dimension lisp file, per CAB's info, but now my icon buttons don't work.  I would like add a link so that you can view the intire folder of icon's and lisp, etc. but don't know how to do that in this forum?
« Reply #14 on: September 24, 2004, 11:00:01 PM »
Here is another way to do your lisp.
(defun c:diml1 ();Sets Text leader to Full scale
  (dsetup "a-anno-text" "r" "l1")
(defun c:diml2 ()
  (dsetup "a-anno-text" "r" "l2")
(defun c:diml4 ()
  (dsetup "a-anno-text" "r" "l4")
(defun c:dimm1 ();Sets dimension to Full scale
  (dsetup "a-anno-dims" "g" "m1")
  (command ".dimlinear")
(defun c:dimm2 ()
  (dsetup "a-anno-dims" "g" "m2")
(defun c:dimm4 ()
  (dsetup "a-anno-dims" "g" "m4")
;;  Function to change layer & dimstyle
(defun dsetup (lay col dstyle / oldcmdecho)
  (if (setq lyr (tblsearch "layer" lay))
    (command ".-layer" "m" lay "")
    (command ".-layer" "m" lay "c" col "" "")
  (if (null (setq dstl (tblsearch "dimstyle" dstyle)))
    (command ".insert"
             (strcat "c:/cadmenu/blocks/" dstytle ".dwg")
             ^c)
  (command ".dimstyle" "r" dstyle)
) ; defun
