I'm losing my mind here with this issue. Here is the code I'm using to draw a table and no matter what the second row comes in as a "Header". Anyone see anything obvious? I'm grabbing all my values from a dataset in case it wasn't obvious.
Note: This has some ugliness to it and I need to cleaned it up after I get the functionality I want. I had converted some Boo code I did to C# using reflector. Not the prettiest output in the world, but it works.
public void DrawBOM()
Document mdiActiveDocument = Application.DocumentManager.MdiActiveDocument;
Database database = mdiActiveDocument.Database;
Editor editor = mdiActiveDocument.Editor;
System.Data.DataTable objBom = new BOMCombiner(this.bomData).getBomTable2();
int dimScale = int.Parse(Application.GetSystemVariable("DIMSCALE").ToString());
DataSet set = new DataSet();
set.Tables.Add(objBom);
this.splitBoms = set;
int currentTableLoc = 0;
int bomTableCount = this.splitBoms.Tables.Count;
if (bomTableCount < 0)
throw new ArgumentOutOfRangeException("max");
while (currentTableLoc < bomTableCount)
int TableLoc = currentTableLoc;
currentTableLoc++;
PromptPointResult point = editor.GetPoint("\nEnter insertion point: ");
Table bmTable = new Table();
bmTable.TableStyle = database.Tablestyle;
bmTable.IsTitleSuppressed = true;
bmTable.IsHeaderSuppressed = false;
bmTable.NumRows = this.splitBoms.Tables[TableLoc].Rows.Count + 1;
bmTable.NumColumns = this.splitBoms.Tables[TableLoc].Columns.Count;
for (int row = 0; row < bmTable.NumRows; row++)
bmTable.SetCellStyle(row, 0, "Data");
int colCount = this.splitBoms.Tables[TableLoc].Columns.Count;
int qtyCols = colCount - 7;
bmTable.SetColumnWidth(colCount - 1, 0.5 * dimScale);
bmTable.SetColumnWidth(colCount - 2, 1.5 * dimScale);
bmTable.SetColumnWidth(colCount - 3, 0.75 * dimScale);
bmTable.SetColumnWidth(colCount - 4, 0.75 * dimScale);
bmTable.SetColumnWidth(colCount - 5, (double) (5 * dimScale));
bmTable.SetColumnWidth(colCount - 6, 0.6 * dimScale);
bmTable.SetColumnWidth(colCount - 7, 1.75 * dimScale);
for (int col=0; col < qtyCols; col++)
bmTable.SetColumnWidth(col, 0.5 * dimScale);
const CellStates cState = CellStates.ContentReadOnly;
bmTable.Position = point.Value;
bmTable.SetRowHeight(0.25 * dimScale);
bmTable.SetTextHeight(0, colCount - 1, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 1, "KSP");
bmTable.SetCellState(0, colCount - 1, cState);
bmTable.SetTextHeight(0, colCount - 2, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 2, "REMARK");
bmTable.SetTextHeight(0, colCount - 3, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 3, "WID.");
bmTable.SetCellState(0, colCount - 3, cState);
bmTable.SetTextHeight(0, colCount - 4, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 4, "LEN.");
bmTable.SetCellState(0, colCount - 4, cState);
bmTable.SetTextHeight(0, colCount - 5, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 5, "DESCRIPTION");
bmTable.SetCellState(0, colCount - 5, cState);
bmTable.SetTextHeight(0, colCount - 6, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 6, "ITEM");
bmTable.SetCellState(0, colCount - 6, cState);
bmTable.SetTextHeight(0, colCount - 7, 0.1 * dimScale);
bmTable.SetTextString(0, colCount - 7, "PART/CAT. No.");
bmTable.SetCellState(0, colCount - 7, cState);
for (int col = 0; col < qtyCols; col++)
bmTable.SetTextHeight(0,col, 0.1 * dimScale);
bmTable.SetTextString(0,col, "QTY. " + objBom.Columns[col].ColumnName.Remove(0,3));
bmTable.SetCellState(0, col, cState);
int x = 1;
foreach (DataRow dr in this.splitBoms.Tables[TableLoc].Rows)
bmTable.SetCellStyle(x, colCount - 1, "Data");
if (dr["ksp"].ToString() == "True")
bmTable.SetTextString(x, colCount - 1, "*");
else
bmTable.SetTextString(x, colCount - 1, "");
bmTable.SetTextHeight(x, colCount - 1, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 1, cState);
bmTable.SetTextString(x, colCount - 2, dr["remark"].ToString());
bmTable.SetTextHeight(x, colCount - 2, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 2, cState);
if (dr["bwidth"].ToString() == "0")
bmTable.SetTextString(x, colCount - 3, "");
else
Fraction wfrac = new Fraction(double.Parse(dr["bwidth"].ToString()));
bmTable.SetTextString(x, colCount - 3, wfrac.ToString() + '"');
bmTable.SetTextHeight(x, colCount - 3, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 3, cState);
if (dr["blength"].ToString() == "0")
bmTable.SetTextString(x, colCount - 4, "");
else
Fraction lfrac = new Fraction(double.Parse(dr["blength"].ToString()));
bmTable.SetTextString(x, colCount - 4, lfrac.ToString() + '"');
bmTable.SetTextHeight(x, colCount - 4, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 4, cState);
bmTable.SetTextString(x, colCount - 5, dr["description"].ToString().ToUpper());
bmTable.SetTextHeight(x, colCount - 5, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 5, cState);
bmTable.SetTextString(x, colCount - 6, dr["partno"].ToString());
bmTable.SetTextHeight(x, colCount - 6, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 6, cState);
bmTable.SetTextString(x, colCount - 7, dr["catalogno"].ToString());
bmTable.SetTextHeight(x, colCount - 7, 0.125 * dimScale);
bmTable.SetCellState(x, colCount - 7, cState);
bmTable.SetTextString(x, col, dr[col].ToString());
bmTable.SetTextHeight(x, col, 0.125 * dimScale);
bmTable.SetCellState(x, col, cState);
x++;
// Enable Table breaking
bmTable.BreakEnabled = true;
bmTable.BreakFlowDirection = TableBreakFlowDirection.Left;
bmTable.BreakOptions = TableBreakOptions.AllowManualHeights | TableBreakOptions.AllowManualPositions | TableBreakOptions.RepeatTopLabels;
Autodesk.AutoCAD.DatabaseServices.Transaction transaction = mdiActiveDocument.TransactionManager.StartTransaction();
BlockTable table3 = (BlockTable) transaction.GetObject(mdiActiveDocument.Database.BlockTableId, OpenMode.ForWrite);
BlockTableRecord record = (BlockTableRecord) transaction.GetObject(table3[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
record.AppendEntity(bmTable);
transaction.AddNewlyCreatedDBObject(bmTable, true);
transaction.Commit();
record.Dispose();
table3.Dispose();
transaction.Dispose();
