Thanks Daniel,Good way to get your feet wet with NET you think?
So that would eliminate the need for ODCL?
Can it work with/create commands for the CLUI?
Quote from: CmdrDuh on October 14, 2008, 02:34:38 PMSo that would eliminate the need for ODCL?I imagine for most lispers, using OpenDCL is (much) easier than using .NET languages to create GUI.
Quote from: danellis on October 15, 2008, 03:05:12 AMCan it work with/create commands for the CLUI?Do you mean 'Command Line User Interface' , or is that a misspelled CUI ?? the answer is 'yes' and 'sortof'.
