Author Topic: Setting Variables  (Read 1817 times)
Setting Variables
« on: September 22, 2004, 01:15:36 PM »
I have a lisp that sets variables at startup. My question is, how do I make the lisp continue if a variable cannot be set?
(defun c:ninjasettings()
(setvar 'acadlspasdoc 1)
(setvar 'apbox 1)
(setvar 'attdia 1)
(setvar 'attmode 1)
(setvar 'auditctl 0)
(setvar 'bindtype 1)
(setvar 'blipmode 0)
(setvar 'cecolor "bylayer")
(setvar 'celtype "bylayer")
(setvar 'cmddia 1)
(setvar 'clayer "0")
(setvar 'coords 2)
(setvar 'delobj 1)
(setvar 'dimassoc 1)
(setvar 'dragmode 2)
(setvar 'dragp1 50)
(setvar 'dragp2 50)
(setvar 'dwgcheck 0)
(setvar 'edgemode 1)
(setvar 'elevation 0)
(setvar 'expert 1)
              (setvar 'explmode 1)
(setvar 'facetratio 1)
(setvar 'facetres 10)
(setvar 'filedia 1)
(setvar 'filletrad 0)
(setvar 'fillmode 1)
(setvar 'fontalt "romans.shx")
(setvar 'grips 1)
(setvar 'hideprecision 1)
(setvar 'highlight 1)
(setvar 'hpbound 1)
(setvar 'imagehlt 1)
              (setvar 'isavebak 1)
(setvar 'isavepercent 0)
(setvar 'isolines 100)
(setvar 'logfilemode 0)
(setvar 'lwdisplay 0)
(setvar 'maxsort 5000)
(setvar 'mbuttonpan 1)
(setvar 'mirrtext 0)
(setvar 'olequality 3)
(setvar 'olestartup 1)
              (setvar 'osmode 0)
(setvar 'pickadd 1)
(setvar 'pickauto 1)
(setvar 'pickfirst 1)
(setvar 'pickstyle 1)
(setvar 'plinegen 1)
(setvar 'plinetype 2)
             ;(setvar 'plinewid 0)
(setvar 'proxyshow 1)
(setvar 'rasterpreview 0)
              (setvar 'rememberfolders 1)
(setvar 'rtdisplay 0)
(setvar 'savetime 5)
(setvar 'sortents 1)
(setvar 'textfill 1)
             ;(setvar 'treedepth -3020)
(setvar 'ucsfollow 0)
(setvar 'whiparc 0)
(setvar 'xfadectl 75)
(setvar 'xloadctl 2)
(setvar 'zoomfactor 90)
(c:ninjasettings)
(princ "\n  Variables Set.....")
Thanks,
Ron
David Bethel
Setting Variables
« Reply #1 on: September 22, 2004, 01:51:20 PM »
If you want to check for the variable's existence
(and (getvar "VarName")
        (setvar value))
If it is read-only, then you have problems.  -David
R12 Dos - A2K
