Author Topic: How do you create your notes and detail sheets?  (Read 15735 times)
CHulse
« on: September 20, 2008, 09:05:25 AM »
Working on a standard process here and I wondered what you all do.
Thanks!
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
Shinyhead
Re: How do you create your notes and detail sheets?
« Reply #1 on: September 20, 2008, 09:55:29 AM »
My vote is in modelspace but printed from paperspace.
This is my general preference as we use annotative dimensioning when we can and its all 2d drafting.
I have seen occasions where having the geometry in MS and annotation in PS makes sense, all in modelspace makes me cringe.  Worse yet are the people so stuck they scale in MS to the titleblock and use dimlfac, that makes me want to scream.
Alan Cullen
« Reply #2 on: September 22, 2008, 03:44:06 AM »
Cary,
I create details and sections in model space so they are to scale 1:1. I work out the plot scale and add notes to the details in model space at the appropriate size to suit final plot scale. I then create a layout tab, add the title sheet at 1:1, then create viewports for each of the details. Set the scales up for the viewports...and Bob's your uncle.
If I need to put largish blocks of notes on the details sheet, I add them onto the detail sheet (not in active viewports) at plot scale of 1:1. It all seems messy...but it works for me.
« Reply #3 on: September 22, 2008, 09:25:17 AM »
Cary,
Allen your process would be much cleaner IF you saved a view around your details in model space, and THEN used sheet set manager to point to the model view drawing and drag your detail views onto your layout tabs using sheet set managers functions.
Willie
  • Going nowhere slowly
« Reply #4 on: September 22, 2008, 10:57:05 AM »
Legend and notes in modelspace.  Add a viewport on paperspace with lengend and notes in the side of the title block.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Julie@Integra
« Reply #5 on: September 22, 2008, 11:24:00 AM »
TitleBlock/Border is in paperspace....
all else in modelspace (drawn 1:1), with scaled viewport(s) in paperspace, and printed from paperspace.
All is well-organized and labeled (on non-printable layers, of course) in modelspace for easy reference, as well.
With a variety of clients, this works best for everyone. I even occasionally detail for a fabricator who prints out TO SCALE from modelspace -- he's got someone who prints on [unspecified] extra L.A.R.G.E. media for him -- so his guys in the shop have a template for stair stringers and other miscellaneous steel items! Crazy, huh?
deegeecees
« Reply #6 on: September 22, 2008, 11:33:17 AM »
I don't use any text in modelspace. I believe this was the intentions of ADesk, to have the ability to create a model as a real world object in Modelspace, and have a means for notation to build it in Paperspace.
jnieman
« Reply #7 on: September 22, 2008, 11:38:17 AM »
annotation scale?
Alan Cullen
« Reply #8 on: September 22, 2008, 11:41:52 AM »
That was last week...but.....arrrrr...Cap'n Boolean challenges me...scurvy dawg that be he. I be saying me scurvy crew does me bidding. you mongrel half cursed son of a happy washer. You been playing half  attempt at a washer be me.....then me be seeing you at yon pier at midnight. Cutlass be fine. arrrrrr
Julie@Integra
« Reply #9 on: September 22, 2008, 11:55:57 AM »
With my previous employer, that's how it was done. But the environment (mainly, several detailers who wouldn't use standardized methods or leave another's drawings alone -- thereby screwing everything up) made it necessary to switch...    I grew accustomed to it, and appreciate the ease of doing it all in modelspace now.
deegeecees
« Reply #10 on: September 22, 2008, 11:57:31 AM »
annotation scale?
I started out in ACad when that wasn't even a thought. They added that after requests. I still don't need to use it.
jnieman
« Reply #11 on: September 22, 2008, 12:00:35 PM »
annotation scale?
Yea, that's my thinking too.  Once I learned how to use paperspace properly, there was no going back... it all made too much sense, after that :)
deegeecees
« Reply #12 on: September 22, 2008, 12:04:50 PM »
I've worked in countless places where I've had to succumb to the practices of someone who had little or no knowledge of the software and how it's intended use was somehow overlooked. Now, I've had the opportunity to start a CAD dept. from the ground up. My work here is all 3D, with the exception of floor plans/elevations/shop drawings. And those are generated with views of the 3D model and notation in paperspace.
Kate M
« Reply #13 on: September 22, 2008, 12:27:45 PM »
Ah, but if you were DRAFTING (i.e. 2D) instead of MODELING (3D), annotating in modelspace might make a lot more sense.
jnieman
« Reply #14 on: September 22, 2008, 12:40:05 PM »
Not to me.
I do drafting and modeling, depending on the project.  Annotation in model space makes zero sense to me.  The company in the back is WELL set up in doing it, and it's terrible compared to the awesomeness of paper-space annotation, imo.
deegeecees
« Reply #15 on: September 22, 2008, 12:42:24 PM »
I've done that too. At ComEd they use only Modelspace, basically crippling some functionality. I've pretty much seen/done most all of everything that is Cad, not just AutoCad, but the likes of ProE, SolidWorks, Unigraphics, and the trend of AutoCad has seemed to usually try to emulate those practices of the high end programs. The parametric design qualities of AutoCad are there, but they aren't as "automatic" as the higher end proggy's.
...and, I DO drafting. I use paperspace for that. Don't make me get all Cadaver on ya, now...
Kate M
« Reply #16 on: September 22, 2008, 04:37:39 PM »
No, no, anything but that! :-D
I guess what I really meant was that yes, for 3D work modelspace annotation is silly, but for 2D i think it's much more a matter of workflow/industry/personal preference.
For the work I did, which involved few if any partial plans or blowups, I much preferred having all the text in the same space as the objects. I don't like working "through" a viewport, and did enough copying around that staying out of paperspace just made sense. For a discipline like civil/roadways, though, where multiple viewports and matchlines are much more common, I could see a strong case made for paperspace annotation. Or like yours, where 2D views are generated from 3D.
We're talking about AutoCAD, anyway -- multiple cat-skinning methods are always supported and encouraged. :-)
sinc
« Reply #17 on: September 22, 2008, 06:23:52 PM »
Then why did they create C3D labels in such a way that they only work in modelspace?
Krushert
  • FREE BEER Tomorrow!!
« Reply #18 on: September 22, 2008, 07:14:58 PM »
Not to me.
What about common annotation that will show up in different sheets and even different files?  One location only to edit.  instead of multiple Paper Spaces to edit.  I agree with Kate, different strokes for different offices.
We do 99.8% of our annotation in model space.  Which model space is our biggest question/debate since we xref a lot.
« Reply #19 on: September 22, 2008, 07:58:16 PM »
I've applied this simple to follow rule: If the dimension is directly related to the model, it belongs in model space.
If it is a simple text annotation, it belongs on the paper(space).
So the Detail A-A label is in paper space, however all notes, and or dimensions required to build Detail A-A are touching the model.
And the reason C3D labels are designed to work in the model space only, is probably to allow them to rotate and scale correctly within your viewports. And they are a part of the model (object) in many instances.
CHulse
« Reply #20 on: September 23, 2008, 08:35:47 AM »
Thanks for all the replys- great discussion.
We got a bit off of what I had intended though (not that that's a bad thing!).
My question was regarding standard/typical construction details and general notes, sequence, specifications and the like and not how to annotate a model.
I do agree with Mike though that annotation relative to the model (dimensions, callouts, specific notes, etc) belongs in the model (at least with the type of work I do-civil and not 3d modeling).
What I am interested in is how everyone creates their sheets full of notes and other support info for a given project. I hope this clarifies some.
Thanks again.
Cary Hulse
« Reply #21 on: September 23, 2008, 08:43:50 AM »
Thanks again.
Typically this is done by inserting the typed documents into mtext.
Or is more typically the case, those 'boiler plate' notes get used and reused by every job.  Of course no one manages to catch the stuff that doesn't belong in there until A)after the reviewer finds it, or B) after the contractor calls about some issue they have with those notes. And THEN they get edited.
deegeecees
« Reply #22 on: September 23, 2008, 09:50:36 AM »
Dunno. Never had the pleasure of using C3D.
I was just saying, the 'original' intentions BEFORE all these verticals came about, when paperspace was introduced, there was a different mindset for workflow. At least from my experience there was. But as time goes by, things do evolve and usually spin off in a direction that echo's the industries demands.
Then again, I could be totally off my rocker.
deegeecees
« Reply #23 on: September 23, 2008, 09:54:28 AM »
I don't know how many times I've used that statement. So true.
hermanm
« Reply #24 on: February 05, 2010, 12:20:33 AM »
Wow. So much for framing square w/ stair gages.:)
I do my 2D drawings about as Julie does. BOM & general notes go in PS as well.
Dimensions and detail annotations are in MS.
I use this product:
http://www.cadnovation.com/en/Prod/mvport/mvport.asp
to help organize & manage viewports.
For views of 3D models, annotation is in PS.
bobbym
« Reply #25 on: April 14, 2010, 11:06:28 AM »
We do nothing but 2D work. Most of our parts look basically the same with different dimensions, so we work with tons of predrawn standards that are not to scale. We modify these standards on every new job and change the dimensions (not true dimensions, just lines with arrowheads inserted at each end with plain text added). Everything we do is in model space, e.g. line work, text, title block, ect. When we do draw a part that doesn't have a predrawn standard, then we will draw full size, with real dimensions, but still everything in model space.
