Author Topic: Retrieving a list of mapped network printers and their paths  (Read 1464 times)
psuchewinner
« on: September 18, 2008, 09:45:16 AM »
Ok,
Hopefully this will be easy for someone but I can not figure out how do retrieve a list of of printers and their associated paths from my computer.  Our printers here are on a network and I would like to be able to populate a list box with the names of the printers that are available (or are mapped) on a users computer.  I am thinking of something like that which appears in the "Printer/Plotter" area of the create a new pagesetup dialog.  Can anyone help?
Re: Retrieving a list of mapped network printers and their paths
« Reply #1 on: September 18, 2008, 09:53:00 AM »
(defun _GetNetworkPrinters ( / WshNetwork oPrinters result i )
    ;;  2007/12/xx Michael Puckett
    ;;  Translated from http://tinyurl.com/2496ow
    ;;  typical result --
    ;;      ("PDFFILE:"       . "Win2PDF")
    ;;      ("XPSPort:"       . "Microsoft XPS Document Writer")
    ;;      ("IP_nn.n.nn.nnn" . "\\\\server\\Plotter Name 1")
    ;;      ("IP_nn.n.nn.nnn" . "\\\\server\\Plotter Name n")
    (setq
        WshNetwork (vlax-create-object "WScript.Network")
        oPrinters  (vlax-invoke WshNetwork 'EnumPrinterConnections)
    ;;  weird, count is a method, not a property of oPrinters
    (repeat (setq i (vlax-invoke oPrinters 'Count))
        (if (zerop (rem (setq i (1- i)) 2))
            (setq result
                (cons
                    (cons
                        ;;  weird, item is a method,
                        ;;  not a property of oPrinters
                        (vlax-invoke
                            oPrinters
                           'Item
                            i
                        (vlax-invoke
                            oPrinters
                           'Item
                            (1+ i)
                    result
    (vlax-release-object oPrinters)
    (vlax-release-object WshNetwork)
    result
psuchewinner
« Reply #2 on: September 18, 2008, 10:48:28 AM »
Perfect, EXACTLY what I was looking for!
Thank you.......Thank you very much.
GDF
« Reply #3 on: September 18, 2008, 01:08:16 PM »
Yes, very nice!
« Reply #4 on: September 18, 2008, 01:50:16 PM »
Thanks guys and you're most welcome.
