Author Topic: .dwg crashes on print  (Read 5004 times)
Re: .dwg crashes on print
« Reply #15 on: August 27, 2008, 12:18:49 PM »
Ok so it prints, but crashes on print preview...???
If one is properly using Named Page Setups, one should have little need to Preview the print, unless one is wanting to take a 'working' break. ;-)
One needs to print the properly configured Layout Tabs, I say not extents. To this I say Nay!
dfarris75
« Reply #16 on: August 27, 2008, 12:26:12 PM »
Yes I know you say nay, but I say YAY! This encourages folks to not leave remnants of past thoughts floating around in paperspace and for the most part it has worked progressively well over time. :-P
And besides, this time around I was simply wanting to print just a small area rather than the entire sheet so I had windowed it and out of habit I always click preview in that case. :-P :-P
Spike Wilbury
« Reply #17 on: August 27, 2008, 12:31:07 PM »
did you try another pc3? and still does not allow to preview?
dfarris75
« Reply #18 on: August 27, 2008, 12:41:57 PM »
Tried another printer altogether. Same error.
Spike Wilbury
« Reply #19 on: August 27, 2008, 12:51:33 PM »
well..... that's strange
I ran here a recover and it find an error on your drawing:
Drawing recovery.
Drawing recovery log.
Validating objects in the handle table.
Valid objects 37059  Invalid objects 0
Validating objects completed.
    Salvaged database from drawing.
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 35000   objects audited
AcDbSpatialIndex(3082C)           was repaired.
Pass 1 37000   objects audited
Auditing Entities Pass 2
Pass 2 37000   objects audited
Auditing Blocks
 297     Blocks audited
Total errors found 1 fixed 1
Erased 0 objects
I use A2007
Spike Wilbury
« Reply #20 on: August 27, 2008, 01:00:40 PM »
after doing the audit or recover and then open the drawing via recover it shows a ton of errors like:
          Error for Entry (209D2) eInvalidInput         was Removed.
AcDbSortentsTable(20CDD)
          Error for Entry (209B7) eInvalidInput         was Removed.
          Error for Entry (20A04) eInvalidInput         was Removed.
          Error for Entry (209CB) eInvalidInput         was Removed.
          Error for Entry (209C4) eInvalidInput         was Removed.
          Error for Entry (209DD) eInvalidInput         was Removed.
          Error for Entry (209B0) eInvalidInput         was Removed.
          Error for Entry (209FD) eInvalidInput         was Removed.
          Error for Entry (209D6) eInvalidInput         was Removed.
          Error for Entry (20A0F) eInvalidInput         was Removed.
          Error for Entry (209A9) eInvalidInput         was Removed.
          Error for Entry (209A2) eInvalidInput         was Removed.
          Error for Entry (209E3) eInvalidInput         was Removed.
          Error for Entry (209BB) eInvalidInput         was Removed.
Spike Wilbury
« Reply #21 on: August 27, 2008, 01:07:25 PM »
and after doing all that, I open the drawing via recover one more time and still it shows:
Audit does not catch it....
below is your drawing saved with A2007, hth
« Reply #22 on: August 27, 2008, 01:25:53 PM »
I think at this point it is no longer a C3D drawing any longer, or is it?
There is NO Surface object in that file.  aaaaghhhhh!!!!!!!
Spike Wilbury
« Reply #23 on: August 27, 2008, 01:29:30 PM »
that's why I rename it..... :)
to exclude any possibilty.... :)  - I should mentioned that...
« Reply #24 on: August 27, 2008, 01:33:14 PM »
you KILLER!!!!!!!   :-o
:-D   :lmao:
dfarris75
« Reply #25 on: August 27, 2008, 02:58:32 PM »
Still doesn't work. I tried the same. Recover > save > Audit > save > Recover > save... It catches one or two errors each time.  :realmad:
« Reply #26 on: August 27, 2008, 04:53:35 PM »
I might just have to fire up a version of 2008 so I can touch it without contaminating it with the 2009 upgrade virus.
For a more detailed look at it.
