Author Topic: .dwg crashes on print  (Read 5000 times)
dfarris75
« on: August 27, 2008, 10:46:39 AM »
I have a file that when I try to print it crashes. It's not an overwhelmingly large file. I'm not sure what may be causing the problem. Any ideas?
dfarris75
Re: .dwg crashes on print
« Reply #1 on: August 27, 2008, 10:51:05 AM »
It crashes on print preview as well. I queried into a new file and the problem remained.
Spike Wilbury
« Reply #2 on: August 27, 2008, 10:52:26 AM »
I have seen it when the .PC3 file is corrupted (and there are no problems with my drawing)....
maybe
dfarris75
« Reply #3 on: August 27, 2008, 10:57:46 AM »
I use the same .pc3 with other files and don't have the problem. :|
« Reply #4 on: August 27, 2008, 11:08:28 AM »
can I see that no printing, no previewing file?
Spike Wilbury
« Reply #5 on: August 27, 2008, 11:14:00 AM »
Things I normally do:
- if the drawing is on a server, I open it local and tested there
- recover, audit
- start from scratch drawing an paste all there...
hth
dfarris75
« Reply #6 on: August 27, 2008, 11:14:36 AM »
It's actually the same file I tried to send you a week or so ago and you said you couldn't even download it. I've been trying to clean it up some, but thus far nothing I've purged from it has had positive results.
« Reply #7 on: August 27, 2008, 11:15:53 AM »
try posting it to a lily pad....
dfarris75
« Reply #8 on: August 27, 2008, 11:20:52 AM »
Try this.
« Reply #9 on: August 27, 2008, 11:26:28 AM »
Sadly I will be infecting your dwg with the 2009 upgrade virus when I close it.
Spike Wilbury
« Reply #10 on: August 27, 2008, 11:27:13 AM »
I ran a test here and it preview your drawing, any of the layouts btw.
copy your file on your pc (local) and try it.... also where is the pc3?
« Reply #11 on: August 27, 2008, 11:30:57 AM »
it plots fine here
dfarris75
« Reply #12 on: August 27, 2008, 11:39:17 AM »
I've tried it on my local. Ran a recover too. It still causes trouble. I've tried to another printer too.
« Reply #13 on: August 27, 2008, 12:03:05 PM »
Print to DWF and then print that....
dfarris75
« Reply #14 on: August 27, 2008, 12:13:12 PM »
Ok so it prints, but crashes on print preview...???
