Author Topic: Bindfix15  (Read 1763 times)
CADwoman
Bindfix15
« on: August 22, 2008, 09:46:52 AM »
Does anyone know how to modify the old bindfix15 command to add a X- in front of the "fixed" layers instead of a numerical suffix? thanks in advance.
Matt__W
  • I like my water diluted.
Re: Bindfix15
« Reply #1 on: August 22, 2008, 11:02:54 AM »
What is the bindfix15 command??!?   :?
Autodesk Expert Elite
CADwoman
Re: Bindfix15
« Reply #2 on: August 22, 2008, 11:58:06 AM »
(defun c:BindFix15
   ;  BindFix15.lsp (AutoCAD 2000+)
   ;  Copyright 2003 · Michael Puckett · All Rights Reserved
   ;  Ver 1.01 2004/04/23 fixed:
   ;     __RenameTableEntry had superfluous local decl. 'data'.
   ;     __RenameTableEntryViaActiveX had superfluous local decl. 'data'
   ;     __StripBindingArtifacts missing local decl. 'ceiling'.
   ;     __GetUniqueTableEntryName missing local decl. 'i'.
      ;  local defuns
      __GetTableEntries
      __RenameTableEntry
      __RenameTableEntryViaObjname
      ;  local vars
      doc
      newname
   ;  local defun __GetTableEntries
   (defun __GetTableEntries ( table / data result )
      (while (setq data (tblnext table (null data)))
         (setq result
            (cons (cdr (assoc 2 data)) result)
      result
   ;  local defun __RenameTableEntry
   (defun __RenameTableEntry ( doc table oldname newname )
      ;  wrapper for __RenameTableEntryViaObjname
      ;  and __RenameTableEntryViaActiveX functions
      (setq table
            ((eq (setq table (strcase table t)) "ltype") "linetype")
            (t table)
      (if (member table '("style" "dimstyle"))
         ;  autodesk made textstyles and dimstyles read-only to
         ;  the automation model w/regards to the symbol name, why?
         (__RenameTableEntryViaObjname table oldname newname)
         (__RenameTableEntryViaActiveX doc table oldname newname)
   ;  local defun __RenameTableEntryViaObjname
   (defun __RenameTableEntryViaObjname ( table oldname newname / data )
      ;  calling function responsible for
      ;  ensuring appropriate data passed
      (entmod
         (subst
            (cons 2 newname)
            (assoc 2 (setq data (entget (tblobjname table oldname))))
            data
   ;  local defun __RenameTableEntryViaActiveX
   (defun __RenameTableEntryViaActiveX ( doc table oldname newname )
      (vla-put-name
         (vla-item
            (eval
               (list
                  (read (strcat "vla-get-" table "s"))
                  doc
            oldname
         newname
      ;  if you wanted this to be more robust
      ;  you could use the following ...
      ;  (vl-catch-all-apply
      ;     (function
      ;        (lambda ()
      ;           (vla-put-name ...)
      ;  I chose to pass valid data instead
   ;  local defun __StripBindingArtifacts
   (defun __StripBindingArtifacts ( entry / i done ceiling )
         (  (wcmatch entry "*`$#`$*")
            (setq i 0 ceiling (strlen entry))
            (while (and (not done) (< i ceiling))
               (if (wcmatch (substr entry (setq i (1+ i)) 3) "`$#`$*")
                  (setq
                     entry (substr entry (+ i 3))
                     done  t
      entry
   ;  local defun __GetUniqueTableEntryName
   (defun __GetUniqueTableEntryName ( table entry / i )
         (  (tblsearch table entry)
            (setq i 1)
            (while
               (tblsearch table
                  (strcat entry "_" (itoa (setq i (1+ i))))
            (strcat entry "_" (itoa i))
         (  t entry  )
   ;  "main"
      (  (< 14 (atoi (getvar "acadver")))
         (setq doc (vla-get-activedocument (vlax-get-acad-object)))
         (foreach table '("block" "dimstyle" "layer" "ltype" "style")
            (foreach entry (reverse (__GetTableEntries table))
                     (__RenameTableEntry
                        doc
                        table
                        entry
                        (setq newname
                           (__GetUniqueTableEntryName table
                              (__StripBindingArtifacts entry)
                     (princ
                        (strcat "\n"
                           (if (tblsearch table newname)
                              (strcat
                                 "Renamed "
                                 table " "
                                 entry " => "
                                 newname "."
                              (strcat
                                 "Could not rename "
                                 table " "
                                 entry "."
      (  t (princ "\nSorry, penned for AutoCAD 2000+."))
TimSpangler
  • CAD Naked!!
Re: Bindfix15
« Reply #3 on: August 22, 2008, 12:08:42 PM »
I believe that Micheal has stepped away.  You may try to email him. Michael Puckett
ACA 2015 - Windows 7 Pro
deegeecees
Re: Bindfix15
« Reply #4 on: August 22, 2008, 12:10:04 PM »
Yeah, MP hasn't been around much lately.
I believe that may throw this routine for a loop, as the number prefix was for unique layer naming. Using X- would create duplicate layer names.
Re: Bindfix15
« Reply #5 on: August 22, 2008, 01:27:27 PM »
You can replace with this version.  Not tested.
   ;  Modoified by CAB 08.21.08  for prefix "X_" or "Xn_"
           (if (tblsearch table (strcat "X_" entry))
               (setq i 1)
               (while
                  (tblsearch table
                     (strcat "X" (itoa (setq i (1+ i))) "_" entry)
               (strcat "X" (itoa i) "_" entry)
             (strcat "X_" entry)
         (  t entry  )
