Author Topic: Cant get c:repref to work in rendering code  (Read 3423 times)
bemiller1
« on: August 16, 2008, 04:45:20 PM »
If anyone is able to figure out why c:rpref doesn't work in the following example of code, I sure would appreciate it"
Command:
(defun rtod (a)
  (/ (* a 180) pi)
;sets render preferences and file options
(defun C:setrender
  (c:rpref "TOGGLE" "SKIPRDLG" "OFF")
  (c:rpref "ROPT" "ASCAN" 2 NIL NIL 0 1 3)
  (c:rfileopt "BMP" 640 480 1.0 "C8")
(defun c:ani (/ cntr deg entgrp fname num rotpnt)
; Turn command echoing off
  (setq cmdold (getvar "cmdecho"))
  (setvar "cmdecho" 0)
; Select the objects
  (setq entgrp (ssget))
; Check to make sure you selected something
  (if entgrp
; Set undo point
      (command ".undo" "Mark")
; Pick rotation point
      (setq rotpnt (getpoint "\nPick rotation point:<0,0,0> "))
      (if (= rotpnt nil)
(setq rotpnt (list 0 0 0))
      (setq num (getint "\nEnter number of images:<15> "))
      (if (= num nil)
(setq num 15)
      (setq deg
     (rtod (getangle rotpnt "\nEnter degrees of movement:<3> "))
      (if (= deg nil)
(setq deg 3)
      (setq cntr 1)
      (repeat num
; Add path here
(setq
  fname (strcat
  "D:\X\Y\Z\TestImage"
  (itoa cntr)
  ".bmp"
; ***renders an image to the specified filename***
(c:render (vl-princ-to-string fname))
; Rotate the object
(command ".rotate" entgrp "" rotpnt deg)
(setq cntr (1+ cntr))
      ) ; repeat
      (command ".undo" "Back")
    ) ; progn
  ) ; if
; Return echo
  (setvar "cmdecho" cmdold)
Thx
Re: Cant get c:repref to work in rendering code
« Reply #1 on: August 16, 2008, 07:15:44 PM »
Doesn't appear that there is a command line version of rpref.
therefore
(c:rpref "TOGGLE" "SKIPRDLG" "OFF")or
(command "rpref" "TOGGLE" "SKIPRDLG" "OFF")will not work.
Perhaps someone who uses render can lend a hand but it's a little slow on the week ends.
So be patient.
bemiller1
« Reply #2 on: August 17, 2008, 11:40:53 AM »
Thanks for quick response, CAB
What makes this a weird problem for me is that when I enter rpref on the command line of AutoCad the render preference dialog box appears yet when inserted in AutoLisp code, with recommended handling for externally defined commands i.e. "C:"prefix it returns "no function definition: C:RPREF"
« Reply #3 on: August 17, 2008, 01:22:08 PM »
Yes, when you try this you get nil
_$ (atoms-family 1 (list "c:rpref"))
(nil)
But after executing from the command line it returns
("C:RPREF")
I think RPREF is a VBA routine and not LISP.
See this is loaded "acrender.arx"
but these don't work eather
Command: (vl-vbarun  "rpref")
_.-VBARUN Initializing VBA System...
Macro name: rpref Execution error
Command: "rpref"
Command: (vl-vbarun  "c:rpref")
_.-VBARUN
Macro name: c:rpref
Macro not found.
Command: "c:rpref"
« Reply #4 on: August 17, 2008, 01:31:01 PM »
jbuzbee
« Reply #5 on: August 17, 2008, 02:34:08 PM »
(vla-SendCommand(vla-get-ActiveDocument(vlax-get-acad-object))"rpref ")
James Buzbee
Windows 8
bemiller1
« Reply #6 on: August 18, 2008, 04:23:38 PM »
jbuzbee,
Looks like it might work for externally defined commands. Being unfamiliar with the vla-type code I'm not totally sure how to integrate it with AutoLisp. I'll take a crack at it. Here is an attempt.
(Would appreciate any comments)
(defun C:setrender
  (setq pref (vla-SendCommand
       "rpref"
    (if entgrp
; Set undo point
(if (= rotpnt nil)
(if (= num nil)
  (setq num 15)
(defun rtod (a)
  (/ (* a 180) pi)
(setq deg
(if (= deg nil)
  (setq deg 3)
(setq cntr 1)
(repeat num
; Add path here
  (setq
    fname (strcat
    (itoa cntr)
    ".bmp"
; Rotate the object
) ; repeat
      ) ; progn
    ) ; if
; Return echo
CAB I had discovered that last bit of code you found, in fact, that was what prompted me to get around problems with "command: render" and attempts to open and set a render dialog box. But now I'm stuck with this "rpref" thing.
bemiller1
« Reply #7 on: August 18, 2008, 04:27:08 PM »
OK I found this
Render settings in LISP
bemiller1
« Reply #8 on: August 18, 2008, 04:35:47 PM »
(nil)
("C:RPREF")
Command: "rpref"
_.-VBARUN
Macro name: c:rpref
Macro not found.
Command: "c:rpref"
Yes there is acrender.arx in my ACAD folder. There must be some way to call it up in AutoLisp. But the how-to is just a bit beyond my reach. (or my grasp)
BTW my ACAD version-2K2 in case that is a factor.
mjguzik
« Reply #9 on: August 18, 2008, 06:04:47 PM »
Typically, you would load an arx file by first checking if it was already loaded in the current application.  You cannot load an arx that has already been loaded in the current application session without first unloading it as arx files are application driven not per document.  See arxload and arxunload.
(if (not (member "lfafunctions.arx" (arx)))(arxload "lfafunctions.arx"))
Then within lisp you would use either use the arx command with prompts or as an arx function depending on how coded in the arx file.  An arx file is just a dll loaded within AutoCad.
;; Command method
(command "_toponotes" "ALL" "")
for arx functions with arguments
;; function method
(setq varlst (lfa_savevarlist "cmdecho" "blipmode" "PLINEWID" "osmode"))
in your case it appears that acrender.arx has "rpref" that doesn't take arguments anymore (2008) or contain the older ads "c:rpref" command.  For the few times tried it complains and keeps bringing up the dialog box.  Doesn't seem to have much support for lisp.
Have you tried importing material presets tied to layers from another drawing file?
MJG
Didge
« Reply #10 on: August 19, 2008, 11:23:11 AM »
I've had a very quick play with your coding and got this working on my Acad 2006 - Hope it helps.
I've added the (INLIST) function to ensure that AutoCAD's rendering extension is loaded in advance.
The  usual (member (arx)...   approach can prove problematic as Autodesk have occassionally changed the name of their rendering extension.
(defun c:ani (/ INLIST rtod cmdold entgrp rotpnt num ang deg cntr)
  (defun INLIST (lst str / cnt ret)
    (setq cnt -1 ret nil)
    (repeat (length lst) (if (wcmatch (strcase (nth (setq cnt (1+ cnt)) lst)) (strcat "*" (strcase str) "*"))(setq ret 1)))
    ret
  (defun rtod (a)(/ (* a 180) pi))
  (if (not (INLIST (arx) "RENDER"))
    (if (not (arxload "acrender" nil))(progn (princ "\nError: unable to locate rendering extension")(exit)))
  (if (setq entgrp (ssget))
      (if (not (setq rotpnt (getpoint "\nPick rotation point:<0,0,0> "))) (setq rotpnt (list 0 0 0)))
      (if (not (setq num (getint "\nEnter number of images:<15> ")))      (setq num 15))
      (if (setq ang (getangle rotpnt "\nEnter degrees of movement:<3> ")) (setq deg (rtod ang)) (setq deg 3))
      (setq cntr 0)
      (c:rpref "DEST" "FILE")
      (c:rpref "TOGGLE" "CACHE" "OFF")
      (c:rpref "TOGGLE" "SKIPRDLG" "ON")
      (repeat num
(c:render (strcat "C:\\TEMP\\TestImage-" (itoa (setq cntr (1+ cntr))) ".bmp"))
« Last Edit: August 19, 2008, 12:12:21 PM by Didge »
Think Slow......
bemiller1
« Reply #11 on: August 19, 2008, 01:21:54 PM »
    ret
      (setq cntr 0)
      (repeat num
Fantastic! I ran it, BINGO! Now I will read carefully through your code changes and learn from a Master.
Very, Very grateful. Thanks so much,
bemiller
« Reply #12 on: August 19, 2008, 02:15:17 PM »
Nice work Didge.
Didge
« Reply #13 on: August 20, 2008, 05:08:12 AM »
Its a pleasure guys, I should've stressed that this coding should only operate in releases upto and including 2006.
I've yet to fathom the wonders of the new rendering engine.
Here's a few more lines worth experimenting with.
(c:rpref "STYPE" "ARENDER") - basic renderer
(c:rpref "STYPE" "ASCAN") - photoreal renderer
(c:rpref "STYPE" "ARAY") - photo raytracing renderer
(c:rpref "TOGGLE" "SHADOW" "ON")
(c:rpref "TOGGLE" "SHADOW" "OFF")
(c:rpref "TOGGLE" "SMOOTH" "ON")   - smooth shading
(c:rpref "TOGGLE" "SMOOTH" "OFF")
(c:rpref "TOGGLE" "FINISH" "ON") - render using materials
(c:rpref "TOGGLE" "FINISH" "OFF") - render without materials
(c:rpref "DEST" "FRAMEBUFFER")  - render to viewport
(c:rpref "DEST" "FILE") - render to file
(c:rfileopt "TIFF" XDIM YDIM 1 COLORS "COMP")  - file output options depend upon acad version.
(c:rfileopt "TGA" XDIM YDIM 1 COLORS 1 "COMP" "UP")
(c:rfileopt "BMP" XDIM YDIM 1 COLORS)
(c:rfileopt "PCX" XDIM YDIM 1 COLORS)
(c:rfileopt "PS" XDIM YDIM 1 COLORS)
*valid values for COLORS are   "MONO" "G8" "C8" "C16" or "C24"
« Last Edit: August 20, 2008, 05:18:35 AM by Didge »
Think Slow......
bemiller1
« Reply #14 on: August 21, 2008, 01:47:45 PM »
Plenty of experimenting ahead, Thanks again! Very impressive. I'm sure it won't be much longer 'til you've fathomed the depths and wonders of the latest rendering engine.
bemiller
