Author Topic: using the ENTER key switch to next field  (Read 1845 times)
Binky
« on: August 07, 2008, 11:48:52 AM »
I would like the ENTER key to act like the TAB.  Not sure how to do that
Hoping that there is an easy way, like a property setting or something I am not seeing.
Anybody out there done this???
sinc
Re: using the ENTER key switch to next field
« Reply #1 on: August 07, 2008, 02:18:06 PM »
It can get tricky.  I think you have to trap the ENTER key before the form gets it.
Here's an example of a TextBox that lets you trap the ENTER key:
using System;
using System.ComponentModel;
using System.Windows.Forms;
namespace Quux.AcadUtilities
    public class QuuxTextBox : TextBox
        protected override bool ProcessCmdKey(ref Message msg, Keys keyData)
            if (SuppressEnter)
                if (msg.Msg == 256 && keyData == Keys.Enter)
                    OnRaiseEnterKeyPressedEvent(new EventArgs());
                    return true;
            return base.ProcessCmdKey(ref msg, keyData);
        [Category("Behavior")]
        [Description("When set, keeps the ENTER key from triggering the form 'OK' button.")]
        public bool SuppressEnter { get; set; }
        /// <summary>
        /// Fires when 'SuppressEnter' is set to TRUE and user hits ENTER key while editing Textbox.
        /// </summary>
        [Category("Action")]
        [Description("Fires when 'SuppressEnter' is set to TRUE and user hits ENTER key while editing Textbox.")]
        public event EventHandler EnterKeyPressed;
        protected virtual void OnRaiseEnterKeyPressedEvent(EventArgs e)
            EventHandler handler = EnterKeyPressed;
            if (handler != null)
                handler(this, e);
This textbox would be used in Forms just like a normal textbox, except if you set the "SuppressEnter" property to TRUE, it will "trap" the ENTER keypress, and fire the event instead of letting the Form handle it.
