Author Topic: Can't find the annotative scales of dynamic blocks.  (Read 2238 times)
Crank
« on: July 26, 2008, 10:55:21 AM »
I'm trying to find the annotative scales of a selected entity.
With this code the scales for most entities can be found:
(defun get_all_scales (ent / annotative lijst n schalen)
(setq annotative (cdr (assoc 360 ent)))
(if annotative (progn
(setq lijst (entget (cdr (assoc 350 (entget (cdr (assoc 360 (entget annotative))))))))
(foreach n (collect 350 lijst)
(setq schalen (cons
(cdr (assoc 300 (entget (cdr (assoc 340 (entget n))))))
schalen
schalen
(defun collect (key lijst / n return)
(foreach n lijst
(if (= key (car n))
(setq return (cons (cdr n) return))
return
(defun c:test (/ ent scalelist)
(setq ent (entget (car (entsel))))
(if ent (setq scalelist (get_all_scales ent)))
(if scalelist
(princ scalelist)
;else
(alert "\nNo annoscales")
However, on dynamic blocks it crashes, because group 350 isn't present.
No problem, it's possible to make an exeption for dynamic blocks, but where is the data stored of the annotative scales? I can't find it... Perhaps someone can point me in the right direction.
Any help is appriciated.
Crank
Re: Can't find the annotative scales of dynamic blocks.
« Reply #1 on: July 27, 2008, 03:09:16 AM »
Found it  :-)
Annotative dynamic blocks do have two 360-groups. You need the one that belongs to AcDbContextDataManager, so you can use:
(defun get_ent_scales (ent / annotative lijst n schalen collect)
    (foreach n lijst
      (if (= key (car n))
    return
    (setq lijst
          [color=red](member '(3 . "AcDbContextDataManager")[/color][color=green]; Get the right 360-code[/color]
            (entget annotative)
          [color=red])[/color]
      (setq schalen
                    (cons
                      schalen
    schalen
« Last Edit: July 28, 2008, 01:40:48 PM by Crank »
ASMI
« Reply #2 on: July 27, 2008, 12:14:48 PM »
You can to retrieve "ACDB_ANNOTATIONSCALES" dictionary of block and walk around XRecords:
(defun Get_Annotation_Dictionary(vlaObj / aDic)
  (if(= :vlax-true
      (vla-get-HasExtensionDictionary vlaObj))
      (vlax-for d(vla-GetExtensionDictionary vlaObj)
       (if(and
   (vlax-property-available-p d 'Name)
   (= "ACDB_ANNOTATIONSCALES"(vla-get-Name d))
   ); end and
(setq aDic d)
); end if
       ); end vlax-for
      ); end progn
    ); end if
 aDic
  ); end of Get_Annotation_Dictionary
Crank
« Reply #3 on: July 27, 2008, 03:21:37 PM »
Thanks ASMI,
Though I already solved it in ALISP, I wanted to try yours.
I don't know much about VLISP, but when I use:
(defun c:test (/ obj lijst)
(setq obj (vlax-ename->vla-object (car (entsel))))
(setq lijst (Get_Annotation_Dictionary obj))
I always get nil as the result. What am I doing wrong?
« Reply #4 on: July 27, 2008, 05:08:22 PM »
Hi Crank,
ASMI left out a step it appears. This gets the correct Dictionary:
(defun Get_Annotation_Dictionary (vlaObj / aDic)
  (if(= :vlax-true
       (if(and
   (= "AcDbContextDataManager" (vla-get-Name d))
   ); end and
(vlax-for e d
   (if (and
(vlax-property-available-p e 'Name)
(= "ACDB_ANNOTATIONSCALES" (vla-get-Name e))
     (setq aDic e)
); end if
       ); end vlax-for
      ); end progn
    ); end if
  aDic
However, the resulting objects don't seem to be exposed enough in the API for what you want:
Quote from: Autocad
; IAcadObject: The standard interface for a basic AutoCAD object
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00d74d3c>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 092a2c10>
;   Handle (RO) = "369C"
;   HasExtensionDictionary (RO) = 0
;   ObjectID (RO) = 2125842016
;   ObjectName (RO) = "AcDbBlkRefObjectContextData"
;   OwnerID (RO) = 2125841792
; Methods supported:
;   Delete ()
;   GetExtensionDictionary ()
;   GetXData (3)
;   SetXData (2)
Crank
« Reply #5 on: July 28, 2008, 04:10:28 AM »
Thanks Jeff, that works.
It's good to have this by the side. Annoscales aren't documented in the DXF-manual and it wouldn't surprise me if Autodesk desides to do it different in a next release.
ASMI
« Reply #6 on: July 28, 2008, 10:12:38 AM »
Need to extract XRecords. I do not want to make it long ActiveX way and use (vlax-vla-object->ename.
(defun Get_Ann_Scales_List(vlaObj / aDic oLst)
  (if(= :vlax-true
       (if(and
   (= "AcDbContextDataManager"(vla-get-Name d))
   ); end and
(setq aDic(vla-Item d "ACDB_ANNOTATIONSCALES"))
); end if
       ); end vlax-for
      (if aDic
  (vlax-for i aDic
    (setq oLst(cons
(cdr
  (assoc 42
   (entget
     (vlax-vla-object->ename i))))oLst))
    ); end vlax-for
  ); end progn
); end if
      ); end progn
    ); end if
  oLst
  ); end of Get_Ann_Scales_List
Usage:
(Get_Ann_Scales_List(vlax-ename->vla-object(car(entsel))))
(4.0 2.0 1.0)
DXF lists for (vlax-vla-object->ename i):
Scale = 1
((-1 . <Entity name: 79cbad10>) (0 . "ACDB_BLKREFOBJECTCONTEXTDATA_CLASS") (5 . "45A") (102 . "{ACAD_REACTORS") (330 . <Entity name: 79cbad08>) (102 . "}") (330 . <Entity name: 79cbad08>) (100 . "AcDbObjectContextData") (70 . 3) (290 . 1) (100 . "AcDbAnnotScaleObjectContextData") (340 . <Entity name: 7c0700e0>) (50 . 0.0) (10 960.372 265.841 0.0) (41 . 1.0)(42 . 1.0) (43 . 1.0))
Scale = 2
((-1 . <Entity name: 79c114c0>) (0 . "ACDB_BLKREFOBJECTCONTEXTDATA_CLASS") (5 . "540") (102 . "{ACAD_REACTORS") (330 . <Entity name: 79cbad08>) (102 . "}") (330 . <Entity name: 79cbad08>) (100 . "AcDbObjectContextData") (70 . 3) (290 . 0) (100 . "AcDbAnnotScaleObjectContextData") (340 . <Entity name: 7c0700e8>) (50 . 0.0) (10 960.372 265.841 0.0) (41 . 2.0) (42 . 2.0) (43 . 2.0))
Scale = 4
((-1 . <Entity name: 79c114d0>) (0 . "ACDB_BLKREFOBJECTCONTEXTDATA_CLASS") (5 . "542") (102 . "{ACAD_REACTORS") (330 . <Entity name: 79cbad08>) (102 . "}") (330 . <Entity name: 79cbad08>) (100 . "AcDbObjectContextData") (70 . 3) (290 . 0) (100 . "AcDbAnnotScaleObjectContextData") (340 . <Entity name: 7c0700f0>) (50 . 0.0) (10 960.372 265.841 0.0) (41 . 4.0) (42 . 4.0) (43 . 4.0))
« Last Edit: July 28, 2008, 10:22:10 AM by ASMI »
