Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Change A script
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Change A script (Read 4250 times)
Global Moderator
Seagull
Re: Change A script
Reply #15 on:
September 19, 2008, 08:06:27 AM »
Thanks for the translations.
I'll get back to you.
Logged
Global Moderator
Seagull
Re: Change A script
Reply #16 on:
September 22, 2008, 10:37:26 AM »
This is what I have so far.
Is the Manual Digging the correct number? [83.80]
Invert Level is 93.80
Last Edit: September 22, 2008, 10:40:48 AM by CAB
Logged
mcn
Guest
Re: Change A script
Reply #17 on:
September 22, 2008, 10:57:25 AM »
hey,
you decrease with 10m, but you have to do with 10cm.
in rest is OK
best regards,
marius
Logged
Global Moderator
Seagull
Re: Change A script
Reply #18 on:
September 22, 2008, 11:06:40 AM »
So the number should be 93.70?
I work in base 12 units so I'm not sure with your units.
Logged
mcn
Guest
Re: Change A script
Reply #19 on:
September 23, 2008, 02:18:02 AM »
yes is correct
i use metric unit in millimeters usually
Logged
Global Moderator
Seagull
Re: Change A script
Reply #20 on:
September 23, 2008, 02:54:45 PM »
Give this a try.
I did a major conversation away from the use of
command
s.
Only had the one data file so there may be some options that I did not test.
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Change A script
