Author Topic: Change A script  (Read 4249 times)
mcn
Change A script
« on: July 25, 2008, 07:42:57 AM »
I have the following program which was created by a friend of mine. The program works very fine, but i want to add some extra features. My friend doesn't have time to do it, so I hope you will help me to do what I want.
I need to insert data from Excel sheets not from .dat files. These is first thing and to do some small customization of the script to add some percentage (%) character for the slope. and to trim the above manhole after the line on the top.
I don't know how to do it, that way I ask you.
Best Regards.
Marius
DEVITG
Re: Change A script
« Reply #1 on: July 25, 2008, 02:53:23 PM »
Did you ask it to the author ??
Please keep the LOG updated and let me know of major changes at:
               ; netaqua@gmail.com
Re: Change A script
« Reply #2 on: July 25, 2008, 04:45:55 PM »
Marius, welcome to the swamp.
Note that reading Excel files is full of little catches that could give you problems.
That being said there are lots of examples of Excel file reading. It is easier to read CSV files
or comma delimited files. Looking at your data file, the data is positionally sensitive.
To me that is the least desirable way to develop a data file.
Will the lisp work on any CAD system as it is?
Do you have a Excel data file for testing?
How much LISP programing can you do?
PS
I see you registered in November of 2007 and just now posting for the first time.
« Last Edit: July 25, 2008, 05:47:36 PM by CAB »
mcn
Re: Change A script
« Reply #3 on: July 28, 2008, 08:22:50 AM »
Yes, I've asked the author, which is my friend.
The second one I have an excel sheet and is working, I translate from excel to .dat file.
I will attach the excel sheet and also i don't know any thing about lisp programing, sorry.
thanks.
DEVITG
Re: Change A script
« Reply #4 on: July 28, 2008, 02:05:26 PM »
so you will work , at least , from the .dat file .
Using LISP , is better to work wit CSV file , also you can get it from the xls , by SAVING AS
It will better if you can upload a DWG sample of what this lisp can do , or wghat do you want to be done.
Re: Change A script
« Reply #5 on: September 16, 2008, 07:54:47 AM »
DEVITG,
Are you the author?
I just opened the lisp in the zip file & found this header:
; PLEASE DO NOT REMOVE THE FOLLOWING LINES
;;; Trasare profil longitudinal CANALIZARE ;;;
;;; Ver. 1.1                    25.04.2005 ;;;
;;;                            NETAQUA srl ;;;
;;;                      Water Engineering ;;;
;;; _______________________________________;;;
DEVITG
Re: Change A script
« Reply #6 on: September 16, 2008, 08:27:49 AM »
DEVITG,
Are you the author?
;;;                            NETAQUA srl ;;;
Hi Cab , no I am not the author .
If you see my first post I put this warning about to ask the author .
               ; netaqua@gmail.com
And he say it is a friend of him.
Re: Change A script
« Reply #7 on: September 16, 2008, 08:41:50 AM »
Thanks, just wanted to be clear.
DEVITG
Re: Change A script
« Reply #8 on: September 16, 2008, 10:36:44 AM »
OK
Clear counts , keep friendship.
mcn
Re: Change A script
« Reply #9 on: September 18, 2008, 04:02:55 AM »
I attached the example of this lisp, what can do.
b.r. marius
Re: Change A script
« Reply #10 on: September 18, 2008, 08:13:19 AM »
I'm not sure because I could not translate the comments but try changing this code:
      (command "text"
       "J"
       "MC"
       (list (+ 1.5 xpar) (- datum 58.0))
       "2.0"
       (- (atof (angtos (atan (/ 13.0 diparr)))))
       panta
To this code:
      (command "text"
       "J"
       "MC"
       "2.0"
       (strcat panta " %") ; <-----<<  Change this
mcn
Re: Change A script
« Reply #11 on: September 18, 2008, 09:02:38 AM »
thanks, works fine, could you help me with another thing. I attached to the file with how is look, but i need another row between invert level and partial length with the following name and equation: Manual digging, invert level-10cm.
best regrds,
marius
Re: Change A script
« Reply #12 on: September 18, 2008, 07:44:16 PM »
If I have some time this weekend but I would need the profil2.DAT file for testing the routine.
I am having problems translating some words from Romanian to English but I think I can overcome that problem.
Re: Change A script
« Reply #13 on: September 18, 2008, 07:53:17 PM »
Words I can not translate are
Trasare
traseaza
oriz
cartus
mcn
Re: Change A script
« Reply #14 on: September 19, 2008, 02:20:51 AM »
Trasare=lining or laying a line
traseaza=create a line from 1 point to another
oriz=horizontal
cartus= it think is the table under the profile, with all the in formations
