It's a little late, but since I've typed them up.
(defun C:ExportSupportPaths (/ strPaths file outputPath)
(setq strPaths (vla-get-supportpath
(vla-get-files
(vla-get-preferences (vlax-get-acad-object)
(setq file (open
(setq outputPath (strcat (getvar "DWGPREFIX") "current_support_paths.txt"))
"W"
(foreach strPath (string_split str ";")
(write-line strPath file)
(close file)
(prompt
(strcat "\nSupport paths exported to \"" outputPath "\".")
(defun string_split (str delimiter / lenStr lenDelimiter start@ lstStr done find@)
(setq lenStr (strlen str)
lenDelimiter (strlen delimiter)
start@ 0
lstStr nil
done nil
(while (and (not done) (<= (1+ start@) lenStr))
(if (setq find@ (vl-string-search delimiter str start@))
(setq lstStr (cons
(if (zerop find@)
(substr str (1+ start@) (- find@ start@))
lstStr
start@ (+ find@ lenDelimiter)
(setq done t
lstStr (cons (substr str (1+ start@)) lstStr)
(if (= start@ lenStr)
(setq lstStr (cons "" lstStr))
(reverse lstStr)
