Now I'm back to my original question? Why should they? If I'm building and selling widgets, I want my widgets to be the best widgets on the market, and I'll do what ever I need to do to keep them that way. Why should I modify my widgets so that they work with widgets that aren't as good as mine? What possible market advantage would that provide for me? It would only allow the inferior widget company to sell his INSTEAD of me selling mine. I don't think so.
Autodesk and Bentley are not in the business of selling dwg and dgn files, they are in the business of selling design software.
Well there's your problem. You're horribly confused about why they are in business. They are NOT in business to sell design software AT ALL, they are in business for one reason and one reason only, to make money. Using an open format limits that capability, at the very least it does NOTHING to improve that capability.
I'm not a simp, I know their primary objective is a profit.
And according to all scorecards they are doing quite well with their current format.
However you are being very presumptions when you say an open format will limit that capability,
If owners of Msta or Intellicad can seamlessly open and save DWGs, Autodesk will not be selling AutoCAD to those individuals or anyone else that buys <downloads> those products. If you think otherwise, I'll question your opening statement in this post.
have you ever heard of something called a "happy customer".
Autodesk has thousands with their current format.
Perhaps you're too nearsighted to understand the value of an open drawing format, but I and others can certainly see the advantages.
Name two advantages to Autodesk for opening their format? .... other than losing sales to other applications.
However Autodesk doesn't care,
They care about their profits, just as I do for my business and any other business owner for his. Open format will reduce those profits.
they have the CAD industry by the short and curly's
You are quite free to use any other application out there for your data.
and they know they can abuse that to lock end users into using their software to access their own data.
Abuse?? How is that abuse?? They are somehow bad guys for being successful? How the heck does that work? Are you successful? If so you're a scumbag if you don't share your work product with me?? Bull.
The file format is just a container for holding data, nothing more.
And Bentley has chosen a different container than Autodesk has chosen, one is not compatible with the other. No biggie, no problem.
Was it even an option for them?
At the time the Bentley brothers developed their application, they were aiming at a level of compatibility with their sugar daddy corporation (Intergraph). Autodesk's DWG wasn't on their radar until they realized it had sucked the lion's share of the PC CAD market out from under them while they were focused on a niche market. Only THEN did the whining about open formats start.
Here's the bigger issue, if you really need open format containers in which to store your data, YOU screwed up. Why in the world did you spend all that money on an application that does not fit your needs?
First and foremost you can save your caps for someone else as I didn't screw anything up.
If you 'NEED" an open format for your data, and YOU chose a closed format in which to keep YOUR data, You indeed SCREWED UP. If you didn't screw up, then you don't really NEED your data in an OPEN fopmat. Make up YOUR mind.
We use AutoCAD for several reasons. One being we have a team well versed in it but mainly because it is what is dictated to us by our customers.
Then the format is your customer's choice, they are the scumbags.
If I had to estimate we currently issue 70-90% of our customer transmittals in DWG format by contract. The rest are distributed as either prints or PDF files. I would estimate that roughly 0.0001% of our drawings have to be issued in DGN format.
Then open formats would do little for you except reduce the development income of your application.
More importantly we ensure important drawing data, such as BOM data, is written out to an external database to later be collected by other processes such as our ERP system which in turn purchasing and manufacturing demand. However this method has points of failure that could be eliminated if our drawings could be read in real-time when the manufacturing release was executed.
Then maybe the issue is your BOM format, or your manufacturing application or your ERP system, which OPEN formats are they?? What format is the data exchange of your BOM?? What are the points of failure?? What part of any of this is Autodesk's fault??
I'm sure we aren't the only company in the world with these issues.
If the application doesn't fit your needs you are quite free to chose something else, just as many other company's do.
Profit Envy?
