Author Topic: How to change all the width of the lwpolyline in many block.  (Read 2408 times)
qjchen
  • Best wishes to all
There are many lwpolyline in many block, I need to change all the polyline width to a new one, just like "30".
I'm unfamiliar with sub entity, could you help me? Thank you very much.
 :-D
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
DEVITG
Re: How to change all the width of the lwpolyline in many block.
« Reply #1 on: June 15, 2008, 06:53:16 PM »
 :-D
Can you upload the dwg .??
FengK
« Reply #2 on: June 15, 2008, 10:30:04 PM »
 :-D
block definition is like a collection, so you can use vlax-for to loop through the  subentities. say you have a block named "BlkName1" and doc is the document object:
(setq colBlk (vla-get-blocks doc)
      blkdef (vla-item colBlk "BlkName1")
(vlax-for obj blkDef
  (if (eq (vla-get-objectname obj) "AcDbPolyline"))
  (vla-put-width obj 30)
« Reply #3 on: June 16, 2008, 01:14:09 AM »
yuanqiu ,
The code Kelie posted should be fine for block instances.
... or do you want to change the original block definition in the BlockDefinitionTable as well ??
kdub in one timeline.
--> Donate to theSwamp<-
qjchen
« Reply #4 on: June 17, 2008, 09:51:40 AM »
To DEVITG
Now I have no such file, I will try to upload it later.
To Kelie
Your code will help me greatly, I think this must be the right and quick way to solve the question.
To Kerry Brown
I dont need to change the original block definition in the BlockDefinitionTable:)
Thank you all very much!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: July 24, 2008, 07:29:14 AM »
(defun c:test (/ s)
 (princ "\n Select the block with a polyline")
 (if (and (setq s (ssget "_+.:S" '((0 . "insert"))))
          (setq s (cdr (assoc 2 (entget (ssname s 0)))))
     ) ;_  and
   (vlax-for
            o
            (vla-item (vla-get-blocks
                       (vla-get-ActiveDocument (vlax-get-acad-object))
                      ) ;_  vla-get-blocks
                      s
            ) ;_  vla-item
    ;;(setq o (vla-item (vla-item (vla-get-blocks (vla-get-ActiveDocument(vlax-get-acad-object))) s)0))
    (if (= (vla-get-objectname o) "AcDbPolyline")
     (vl-catch-all-apply 'vla-put-ConstantWidth (list o 30.))
    ) ;_  if
   ) ;_  vlax-for
   (foreach x (mapcar (function cadr)
                      (ssnamex (ssget "_x" (list (cons 2 s))))
              ) ;_  mapcar
    (vla-update (vlax-ename->vla-object x))
   ) ;_  foreach
  ) ;_  progn
 ) ;_  if
qjchen
« Reply #6 on: July 24, 2008, 08:22:28 AM »
Thank you, Evgeniy, it do work.
Thx.
