Author Topic: Question: samples\entity\hilight_dg of SDK2009  (Read 3370 times)
ahlzl
« on: June 14, 2008, 05:41:02 AM »
if visualstyle is "2dWireframe" ,OK!
but isn't, Select edge might fail!
MickD
  • (x-in)->[process]->(y-out)
Re: Question: samples\entity\hilight_dg of SDK2009
« Reply #1 on: June 14, 2008, 09:14:29 PM »
Do you have a little more information for us ahlzl?
If I get want you mean, when 'picking' objects on the screen you are actually picking pixels which are traced back to their owners that draw them such as a line, edge or face. If it's not 2d wire frame (all lines/edges) it becomes very hard to determine an edge when the whole face is rendered as the edge is also rendered, if that makes sense.
ahlzl
« Reply #2 on: June 14, 2008, 10:08:33 PM »
thank you, MickD .
but use AutoCAD command ——"solidedit", Select edge success 100% in any visualstyle !!!
How modify SDK's code?
thanks
MickD
« Reply #3 on: June 14, 2008, 11:06:58 PM »
Ok, when using the acad command it highlights the edges yes? This allows you to be able to pick the isolated highlighted edge. In you code you need highlight the object, have a look at 'highlighting' in the help doc's, you may also need to catch the mouse over event or similar to imitate how autocad does this without actually picking an object.
Do you have any code so far we might be able to help you with?
ahlzl
« Reply #4 on: June 14, 2008, 11:45:32 PM »
thanks again !
I write C# code, also fail !
using Autodesk.AutoCAD.Colors;
namespace ABC
    public class Class1
        [CommandMethod("test")]
        public void MyTest()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                TypedValue value = new TypedValue((int)DxfCode.Start, "3DSOLID");
                TypedValue[] values = { value };
                SelectionFilter sfilter = new SelectionFilter(values);
                PromptSelectionOptions opt = new PromptSelectionOptions();
                opt.SingleOnly = true;
                PromptSelectionResult res = ed.GetSelection(opt, sfilter);
                if (res.Status != PromptStatus.OK)
                    return;
                SelectionSet ss = res.Value;
                ObjectId objId = ss[0].ObjectId;
                Solid3d ent = (Solid3d)trans.GetObject(objId, OpenMode.ForWrite);
                int marker = ss[0].GraphicsSystemMarker;
                Matrix3d xform = Matrix3d.Identity;
                Point3d pickPoint = new Point3d(0, 0, 0);
                FullSubentityPath[] pathes;
                try
                    pathes = ent.GetSubentityPathsAtGraphicsMarker
                        (SubentityType.Edge, marker, pickPoint, xform, 0, null);
                catch (System.Exception e)
                    ed.WriteMessage("\n" + e.Message);
                    return;
                ent.Highlight(pathes[0], false);
                ed.GetString("\nEnter...");
                ent.Unhighlight(pathes[0], false);
                Color myColor = Color.FromColorIndex(ColorMethod.ByColor, 1);
                SubentityId edgeId = pathes[0].SubentId;
                ent.SetSubentityColor(edgeId, myColor);
                trans.Commit();
I declare fail, and wait  MickD、 Daniel、 other man  ……
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: June 15, 2008, 12:44:06 PM »
I tried your routine. It does seem like a bug.  You might post it at the Autodesk Discussion Groups to see if anyone has an alternative method. Sorry I couldn’t be of much help  :oops:
Retired
ahlzl
« Reply #6 on: June 15, 2008, 07:39:10 PM »
:oops:
