why is it when you have a routine that only uses entmod and doesn't have any "(command)", if you undo the routine, it will undo what was done with the routine and the last thing performed before the routine was ran?
i put a "(command "layer" "")" as the first thing the routine issues and that works (and that still, if you undo, will undo routine, then undo group, then undo the last thing performed), but i feel that i just don't know something? i've encountered this issue numerous times on routines i did not write, so it's not just me.
