Author Topic: Importing Page Setups  (Read 1336 times)
psuchewinner
« on: June 12, 2008, 04:59:24 PM »
Does anyone know what really happens in AutoCAD when a page setup is imported?  If I use the page setup manager to import a pagesetup, a new dictionary is created in the ACAD_PLOTSETTINGS dictionary and the newly imported pagesetup will be accessable with the publish command.  Something else must be happening.  I say this because if I create a dictionary in the ACAD_PLOTSETTINGS dictionary, it will appear in the pagesetup manager but it will not be accessable from the publish command, it will not show up as an available page setup there.
Joe Burke
Re: Importing Page Setups
« Reply #1 on: June 13, 2008, 10:06:54 AM »
You may need to look at the ModelType property of a plotconfig object. For instance, if the ModelType is -1 that plotconfig only applies to model space. It will not be available in paper space.
