Author Topic: need help setting printer config. search path for lisp PLEASE PLEASE PLEASE  (Read 1764 times)
alanjt
  • Standby for witty remark...
does anyone either know the vla codes or have a routine that will will set the "Printer Configuration Search Path" i have this one for setting the "Plot Style Table Search Path".
any help would be GREATLY appreciated.
here's the code for setting the "Plot Style Table Search Path":
(setq prefs(vla-get-preferences (vlax-get-acad-object))
      filePrefs (vla-get-files prefs)
(vla-put-printerstylesheetpath filePrefs "G:\\cadd standards\\Plotstyles")
(vla-refreshplotdeviceinfo
  (vla-get-activelayout
   (vla-get-activedocument
     (vlax-get-acad-object))))
(setq prefs nil)
(setq fileprefs nil)
Dropbox
Arch_Eric
Put this in the VLIDE editor and inspect it.....
It will show you all you need and more  :-P
alanjt
oh man, thank you guys soooo much.
just so it's here in case someone else needs it:
(vla-put-PrinterConfigPath filePrefs "c:\\path\\path")
(setq prefs nil)
Dropbox
