Code Red > VB(A)
WhoHas
ImaJayhawk:
Is there a way to add some code to a template drawing that will check to see if the person opening the drawing has the WhoHas.arx loaded? And if not attempt to load it?
Thanks.
--ImaJayhawk
MP:
Abbreviated -
--- Code: ---(if
(null
(member
(setq app "WHOHAS.ARX")
(mapcar 'strcase (arx))
(arxload app)
--- End code ---
This assumes whohas.arx is a legitimate app in the support path. You may need to add add'l code to make this bullet proof.
Keith™:
MP, that lisp must be loaded each time to make it effective and if you load it on every drawing, it does not meet the criteria to load when a certain template is used.
You can create a VBA application, and embed the macro in the drawing file using the VBA manager.
MP:
Note to self: have coffee before starting to post. I saw template, not template dwg, and assumed the poster just meant their startup lisp.
JohnK:
No thats cool MP; You can use that code. Use a Persistant reactor. (Although i highly recomend you dont, but you could if you were brave.)
Navigation
[0] Message Index
[#] Next page
Go to full version
