I was revisiting this topic just now and came up with another thought. I wanted to have a label, or at least a tick that marked where the intersections are, but I didn't want one at every horizontal geometry point. After some pondering I decided perhaps adding a station equation with the same back and ahead station assigned would perfectly suit. This way I have a little more control over the display.
I wonder, do later releases have something more favorable for labeling intersections in profile view?
something i've done in the past - create an alignment station offset label with reference text in it that references the other alignment and the two profiles. put that in your plan. then drag it to the profile view (don't move it, drag it). you'll probably want to turn off the leader.
this way you'll be able to see the elevations of both profiles in your profile view.
