Author Topic: Visual Studio 2008 SP1 Beta: WARNING  (Read 7780 times)
« on: May 14, 2008, 05:34:27 AM »
Peter Bromberg's UnBlog
Today, 14 May 2008, 8 hours ago
http://feeds.feedburner.com/blogspot/lGrQ
Quote from: Peter
Dear Microsoft: <snip>
Tuoni
  • I do stuff, and things!
Re: Visual Studio 2008 SP1 Beta: WARNING
« Reply #1 on: May 14, 2008, 07:52:54 AM »
Kerry, I don't get anything apart from a blank page with "done" at the bottom - could you check the link, please?
Reject that... only appears to work in IE ¬_¬
« Last Edit: May 14, 2008, 08:01:22 AM by Tuoni »
Chuck Gabriel
« Reply #2 on: May 14, 2008, 08:07:07 AM »
It worked okay for me with Firefox 3.0 Beta 5 (but it does render more nicely in IE).
Tuoni
« Reply #3 on: May 14, 2008, 08:09:10 AM »
Still on 2.0.0.14 (I avoid betas of anything for the most part) and I just get a blank page :|
sinc
« Reply #4 on: May 14, 2008, 08:30:12 AM »
The link works fine for me on Firefox 2.0.0.14.
Tuoni
« Reply #5 on: May 14, 2008, 08:33:12 AM »
Hmmmn.  That's weird :|
Chuck Gabriel
« Reply #6 on: May 14, 2008, 08:50:35 AM »
Must be an add-on.  I have Adblock Plus, IE Tab and PDF Download installed.
Tuoni
« Reply #7 on: May 14, 2008, 08:54:08 AM »
I have FireBug, Free Download Manager, Temporary Inbox and Torbutton.  Ah well :)
« Reply #8 on: May 14, 2008, 11:24:16 AM »
Worked for me too ( Firefox 2.0.0.14 ).
Tuoni
« Reply #9 on: May 14, 2008, 11:28:31 AM »
Ok, ok, I get it... My FF is screwed :-P :wink:
Chuck Gabriel
« Reply #10 on: May 14, 2008, 12:12:40 PM »
Hey Tuoni!  Did you know your FF is screwed up? :-p
Tuoni
« Reply #11 on: May 14, 2008, 12:22:11 PM »
No?  When did this happen? :-o
 :angel:
sinc
« Reply #12 on: May 14, 2008, 12:55:36 PM »
I have CoolIris, DictionarySearch, DownloadStatusbar, FireFTP, Forecastfox, IE Tab, Map+, and Signature installed, and have no problems.
Tuoni, I think your FF is screwed up.
Tuoni
« Reply #13 on: May 14, 2008, 01:08:38 PM »
:-P
MickD
« Reply #14 on: May 14, 2008, 06:09:16 PM »
Aaannyway,
Looks like the features 'we need to have' have struck again.
The funny thing is, to work a simple/limited gui or even a command type interface isn't that hard to learn, I'd even say it promotes automation better as people soon learn the value and process of scripting, unleashing all sorts of automation possibilities.
But, that wouldn't give software vendors anything new to sell I guess :laugh:
- John Carmack
- J.R.R. Tolkien
