John,
I will answer all the questions in another presentation (possibly today).
Most importantly I had no bowties, and If I had (most likely with the daylight element, I could have either edit the daylight slope values in those stations as an over ride, OR attached the daylight object to an alignment to control the limits of daylighting.
The Design starts with Top of Curb PGL, and all others are derived from that.
HINT: The outside lane is Following the Lip of gutter Alignment (0.05') away from the ETW, almost like a construction joint.
Note I could have done this with a different assembly at the bus bay, that would require the use of multiple regions.
