Author Topic: Object Fields, UCS  (Read 1087 times)
rkmcswain
Object Fields, UCS
« on: May 09, 2008, 11:38:49 AM »
Is there any way to reference non-WCS coordinates in a FIELD that is referencing an object?
For example, the center of a circle in WCS may be 5000,5000 - but in a UCS it may be -212.81,-789.63
If you are in the UCS and create a FIELD referencing that circle, and use the Center property, it says the circle is at 5000,5000.
Maybe tying coordinate FIELDS to the "current" UCS is not a good idea, but I was hoping you could somehow use a "named" ucs.
