Author Topic: String - List Comparison  (Read 2411 times)
« on: May 02, 2008, 12:53:04 PM »
I have been using this to see if a sample string is in the target string
InStr(1, UCase(strNames), UCase(TestString), vbTextCompare)
but without realizing it I have a bigger problem now ... sometimes I have similar strings and the return value is true when I expect false .. for example when "ID1" is the test string and "ID10" is already in the string ...
I'd like to have a better method of doing the comparison, but it needs to be efficient.
I'll take any suggestions
Re: String - List Comparison
« Reply #1 on: May 02, 2008, 12:58:20 PM »
nevermind ... I figured it out ..my string is comma delimited so I changed the check to
InStr(1, UCase(strNames), UCase(TestString) & ",", vbTextCompare)
The string also always ends with a comma so all is good ..
Bob Wahr
« Reply #2 on: May 02, 2008, 08:23:56 PM »
I thought ID10 was always followed by a T
« Reply #3 on: May 02, 2008, 11:22:22 PM »
 :roll:
 :laugh:
