Author Topic: Delete Scalelist  (Read 2175 times)
Willie
  • Going nowhere slowly
Delete Scalelist
« on: April 29, 2008, 10:12:20 AM »
Just something I came across.
We had one user complaining about a drawing that takes ±20 minutes to open with 2008. With 2006, the drawing opens without any problems. Luckily I have read somewhere about problems people are having with the number of scales in the scalelist.  The drawing had 27629 scale list entries.
I found this on the Autocad website, and it solved the problem.
http://discussion.autodesk.com/thread.jspa?messageID=5787101
Re: Delete Scalelist
« Reply #1 on: April 29, 2008, 10:58:48 AM »
Good to know :) ... I was working on a project a couple of weeks ago that took forever to open....I reset the scales and they open right away now.  :-)
Gliderider
« Reply #2 on: April 29, 2008, 11:59:11 AM »
« Reply #3 on: April 29, 2008, 12:31:52 PM »
Nice. I wonder if they have a similar utility for registered applications  8-)
Gliderider
« Reply #4 on: April 29, 2008, 01:02:44 PM »
If you use the command line version of Purge (-purge) there is an option for purging regapps.
« Reply #5 on: April 29, 2008, 01:13:41 PM »
That is what I do now :). What I'd really like is a batch regapp clean utility that would not change the files modify date after purging.
jonesy
  • SuperMod
« Reply #6 on: April 30, 2008, 05:46:03 AM »
Please excuse my ignorance, but what does this do?
« Reply #7 on: April 30, 2008, 09:51:37 AM »
It purges registered applications from the drawing. Sometime there are thousands of these in drawings and it really bloats the file size. The one I always run into that usually has large numbers is EPAN*.
jonesy
  • SuperMod
« Reply #8 on: April 30, 2008, 09:57:36 AM »
I know this may sound strange, but what "registered applications"?
What causes them and how do they get in your drawing?
« Reply #9 on: April 30, 2008, 10:53:58 AM »
I believe reg apps are added when third party programs utilize xdata.
jonesy
  • SuperMod
« Reply #10 on: April 30, 2008, 11:33:32 AM »
Thanks for that :)
So I take it that it SHOULD be OK to purge them out?
