Dynamic Block Angle Property
surveyor_randy:
Could someone tell me how I can access the Custom property "Angle" in a dynamic block. Not the block rotation, but the angle of a rotation action. I am trying to design some lisp that will allow my dynamic north arrow to sync with the twist angle of a selected viewport. Any information you provide would be greatly appreciated. Thanks!
Jeff_M:
You need to use the GetDynamicBlockProperties method of the DB, then cycle through the returned object(s), checking the PropertyName value, until you get the property you want to read/set.
ronjonp:
Maybe some of this code can help you:
http://www.theswamp.org/index.php?topic=21164.msg256839#msg256839
Here is a routine I put together to insert north arrows at the same rotation as the twist angle of the pspace viewport.
http://www.theswamp.org/index.php?topic=19285.msg234429#msg234429
surveyor_randy:
--- Quote from: Jeff_M on April 21, 2008, 04:29:52 PM ---You need to use the GetDynamicBlockProperties method of the DB, then cycle through the returned object(s), checking the PropertyName value, until you get the property you want to read/set.
--- End quote ---
Hi Jeff!
Thanks for the reply, I looked through the help file and the functions and didn't see any 'GetDynamicBlockProperties' functions. Then I went to Autodesks website and searched and found that it is 'vla-getdynamicblockproperties' and it seems that you have to use it in combination with safearray and variant... hmmm... strangely like VBA! :-)
Where can I find more documentation on the 'vla' based commands, since I didn't see it in the 'V' section of the functions help file. I really appreciate your time and input! I am fairly strong in VBA and am picking up lisp fairly quickly thanks to everyone at The Swamp. Thanks again everyone!
surveyor_randy:
--- Quote from: ronjonp on April 21, 2008, 05:28:05 PM ---Maybe some of this code can help you:
--- End quote ---
Wow! Very nice code! I am still learning lisp and your sample code will be a great study for me! I can't believe how powerful Lisp really is. I've spent all this time in VB and had no idea. Great code and thanks for sharing it with us! :-)
PS - I hope you don't mind if I borrow this code temporarily for work!
Navigation
[0] Message Index
[#] Next page
Go to full version
