Author Topic: Block select Lisp needed...  (Read 17406 times)
hudster
« on: August 26, 2004, 05:03:23 AM »
I'm looking for a lisp that will allow me to move blocks to a new layer depending on their attribute values.
I need to move emergency lighting blocks only to a new layer for building warrant purposes, and It's a bit of a pain having to manually change each one to a new layer.
The blocks all have attribute values ending in E.
Cheers for any help
Andy.
SMadsen
« Reply #1 on: August 26, 2004, 07:44:22 AM »
You could choose to write it yourself.
- Make a selection set of all blocks with attributes {hint: '((0 . "INSERT")(66 . 1)) }
- Run through each insert in the selection to test for attribute values {hints: ENTNEXT and WCMATCH}
- Remove any insert that doesn't match {hint: SSREMOVE}
- Return finished selection set
« Reply #2 on: August 26, 2004, 08:45:24 AM »
Quote from: SMadsen
I don't see that in my docs Stig, is that one of your functions?
« Reply #3 on: August 26, 2004, 08:51:22 AM »
I think he meant ssdel. :)
daron
« Reply #4 on: August 26, 2004, 08:51:45 AM »
I was wondering the same thing.  ssdel comes to mind though.
SMadsen
« Reply #5 on: August 26, 2004, 09:01:26 AM »
Doh! Yep, SSDEL  :roll:
« Reply #6 on: August 26, 2004, 09:04:32 AM »
Stig you ready for another race?
SMadsen
« Reply #7 on: August 26, 2004, 09:12:07 AM »
Bring it on :)
What kind, where, how?
« Reply #8 on: August 26, 2004, 09:16:01 AM »
I'm thinking of solving the problem posted by Hudster. I have (almost) the solution using VLAX methods.
hudster
« Reply #9 on: August 26, 2004, 09:22:03 AM »
I've not quite got the necessary skills regarding selection sets yet.
I'm only at the lisp stage where I can write basic routines. :(
***edit***
Stig, are your autolisp lessons nearly ready?
« Reply #10 on: August 26, 2004, 10:10:56 AM »
Here is my first shot at it. It is rather slow.
(defun startTimer ()
  (setq time (getvar "DATE"))
(defun endTimer (func)
  (setq time    (- (getvar "DATE") time)
        seconds (* 86400.0 (- time (fix time)))
  (gc)
  (outPut seconds func)
(defun outPut (secs def)
  ;(princ "\nPurging...")
  ;(command "PURGE" "Layers" "*" "N")
  (gc)
  (princ (strcat "\nTimed " def ": " (rtos secs 2 6)))
(defun get-mspace ()
  (vla-get-modelspace
    (vla-get-activedocument
      (vlax-get-acad-object)
(defun check-for-char (obj char / attrib-list ans_lst)
  (setq attrib-list
        (vlax-safearray->list
          (vlax-variant-value
            (vla-GetAttributes obj)
  (mapcar
    '(lambda (x / ts)
       (setq ts (vla-get-textstring x))
       (cond ((= (substr ts (strlen ts)) char)
              (setq ans_lst (cons "yes" ans)))
    attrib-list
    ); mapcar
  (if (vl-position "yes" ans_lst)
    T nil
(defun chg-blk-to-lay (/ mspace o_name has_attrs)
  (setq mspace (get-mspace))
  (startTimer)
  (vlax-for blk mspace
            (setq o_name (vla-get-objectname blk))
            (cond ((= o_name "AcDbBlockReference")
                   (cond ((vlax-property-available-p blk 'HasAttributes)
                          (if (check-for-char blk "E"); change the char here
                            (vla-put-layer blk "0"); change layer name here
                   ); 1st cond.
                  (T (princ "\r searching ............."))
  (endTimer (vl-symbol-name 'chg-blk-to-lay))
SMadsen
« Reply #11 on: August 26, 2004, 10:13:33 AM »
Here's a simple take on it. A bit primitive at the command interface but you can change it to whatever suits the task best
(defun getAttrib (ent val / att blk entl)
  (setq blk ent)
  (while (and ent (/= "SEQEND" (cdr (assoc 0 (setq entl (entget ent))))))
    (and (= "ATTRIB" (cdr (assoc 0 entl)))
         (wcmatch (cdr (assoc 1 entl)) val)
         (setq att blk)
    (setq ent (entnext ent))
  att
(defun ss_attval (/ a ent sset)
  (cond ((setq sset (ssget "X" '((0 . "INSERT") (66 . 1))))
         (setq a 0)
         (repeat (sslength sset)
           (setq ent (ssname sset a)
                 a   (1+ a))
           (and (not (getAttrib ent "*E"))
                (ssdel ent sset)
                (setq a (1- a)))
  sset
(defun C:ATTLAY (/ ss)
  (cond ((setq ss (ss_attval))
         (command "_CHPROP" ss "" "Layer")
Thanks for the reminder on the lessons. I've been a bit hung up this summer so they're not entirely translated yet. But enough to start it up and get translations ready during.
SMadsen
« Reply #12 on: August 26, 2004, 10:14:06 AM »
Dang, 3 minutes late :)
SMadsen
« Reply #13 on: August 26, 2004, 10:18:13 AM »
By the way, Mark. I've developed a preference for the MILLISECS variable. It's quite accurate and easier to deal with for timers
(setq time (getvar "MILLISECS"))
(setq time (/ (- (getvar "MILLISECS") time) 1000.0))
(princ (strcat "Elapsed time: " (rtos time) " seconds"))
« Reply #14 on: August 26, 2004, 10:23:06 AM »
I just changed mine a bit but it didn't help!
thanks Stig that's nice.
