http://www.theswamp.org/index.php?topic=22395.msg269583 - msg269583
---Rotation of attributed blocks programmatically causes the attributes' rotation to behave erratically.
Rotation of attributed blocks in property window causes the attributes' rotation to behave erratically.
http://www.theswamp.org/index.php?topic=22395.msg269870 - msg269870
Slicing bug does not allow proper function of slice command.
http://www.theswamp.org/index.php?topic=22395.msg269877 - msg269877
Minor error in slice command (very minor)
http://www.theswamp.org/index.php?topic=22395.msg269994 - msg269994
Helix command does not actually draw a helix.
http://www.theswamp.org/index.php?topic=22395.msg270617 - msg270617
Improper display of edge lines includes tangential lines.
http://www.theswamp.org/index.php?topic=22395.msg270618 - msg270618
When the newer visual styles (since 07) are used, linework does not obey plot styles.
I guess not being able to produce functional construction drawings from a model is insignificant, then?
It seems to me that your whole point of the thread was not to document the errors but rather to shove a finger in the face of the people voicing complaints as if they have nothing to complain about. If you have something productive to add, great, but simply looking at all these people's posts and scoffing at them saying that there hasn't been anything of substance posted is just plain rude.
Also, it's not like this thread is very old. Give some people time to remember the bugs. I know I, for one, tend not to think of them because I've become so accustomed to working around them, these workarounds seem as first nature, rather than a bump in the road. I'm used to having to slow to a crawl for the speed bumps, that I forget they're there, I guess.
I have been on the same 2D project for the duration of this thread, and for the most part doing redlines, and haven't touched a decent bit of the more intense 2D drawing, and no 3D modeling at all so far. I'm sure I'll stumble upon more gems to share.
You're asking for skewed results by demanding they be reproducible and demonstrable.
Simple. "This happens <insert your value for frequency > "
"When I do < this> and <this> and <this> ; sometimes < this> happens "
If you would have paid attention to the entire post, and not taken one statement out of context only to belittle my intelligence, you would have gotten the point. The point is, that not all bugs are consistent.
Sure, some people here don't experience the hatch boundary selection, but I made a point to ask a few other CAD managers at other companies. Not one person I've talked to in person has NOT experienced Autocad hanging up when using 'pick a point' method of obtaining a hatch boundary. Everyone in my company has had the problem. Everyone in the other company in the building. Everyone in three associated mechanical, electrical, and civil firms experience it. Confirmed that it happens with an architectural firm we are dealing with. Of the surveyed answers, I and only one other company use 3D tools. Software varies from plain CAD, to ADT, to Autocad Electrical, to simple OOTB no customization vanilla, to heavily customized vanilla...
Here, Kerry, if it makes you feel better:
Autocad hangs up sporadically. When I do "pick point" method of selecting hatch boundary sometimes Autocad locks up into a non-responsive mode. This can not be consistently linked to any other behavior, geometry, commands, etc.
Was that the proper format?
