Hi, I just got two new CAD stations in the office which run on WinXP Pro x64 Operating System. Most of our office printers I was able to install and configure over the network once I downloaded the proper x64 bit drivers except for our Oce9400 plotter. I can't seem to install it properly over the network even with what I think is the proper driver that supports x64bit WinXP. Downloaded from the oceusa.com website. ->
Driver Download PageDoes anyone have experience with this particular Oce plotter and installing the printer on a x64 OS?
The plotter server machine is running Windows 2000 I believe. Normally on the other workstations in the office (Win2000/XP Pro), I'd just go into the printer control panels and add printer. Select the proper configurations for a network printer, select the printer and that it usually installs properly. On the x64 bit systems when I try to install the Oce9400 plotter I get a prompt that there are no compatible drivers avail, then I get prompted to browse and select, which is what I want to do, but when I point to the folder where the downloaded drivers were extracted and hit OK, I get an error. I didn't write down the error message but if it helps I will post it when I encounter it again.
Appreciate any help.
Thanks,
Rob
