Author Topic: viewport limits routine help  (Read 2645 times)
ELOQUINTET
« on: August 24, 2004, 03:43:43 PM »
hey guys i would like to modify this routine so it puts the box created on defpoints layer not the current layer. how do i modify this don't see anything about layers here but i'm not as sharp as you guys so....
;Tip1687:   VPLIM.LSP     Pspace Limits in Mspace (c)2001, Murray Clack
 ;VPLIM.lsp draws the limits of a Paperspace Viewport Boundary in MODELSPACE
 ;VP - Get ViewPort object
 ;HT - Get Outside HeighT of Viewport
 ;WD - Get Oustide WiDth of Viewport
 ;VN - Get Viewport Number
 ;CTR - Get CenTeR of Viewport
 ;CTRX - Caluculate X of Viewport CenTeR
 ;CTRY - Caluculate Y of Viewport CenTeR
 ;VS - Get View Size of viewport
 ;XP - Calculate XP factor of viewport
 ;IW - Calculate Width of viewport
 ;BL - Calculate Bottom Left corner of viewport
 ;BR - Calculate Bottom Right corner of viewport
 ;TR - Calculate Top Right corner of viewport
 ;TL - Calculate Top Left corner of viewport
 ;PW - Save PlineWid
 ;OS - Save OSmode
 ;start function and define variables
(defun
     C:VPL (/ VP HT WD VN CTR CTRX CTRY VS XP IW BL BR TR TL PW OS
 ;turn off command echoing
  (setvar "cmdecho" 0)
 ;enter pspace
  (command ".pspace")
 ;select viewport boundary
  (setq VP
         (entget
           (car (entsel
                  "\nSelect Viewport to Draw Boundary
             in "
                ) ;_ end of entsel
           ) ;_ end of car
         ) ;_ end of entget
  ) ;_ end of setq
 ;Get Viewport height with
  (setq HT (cdr (assoc 41 VP)))
 ;Get Viewport width with
  (setq WD (cdr (assoc 40 VP)))
 ;Get Viewport Number
  (setq VN (cdr (assoc 69 VP)))
 ;enter mspace
  (command ".mspace")
 ;set correct viewport
  (setvar "cvport" VN)
 ;set UCS to View
  (command ".ucs" "v")
 ;Get VIEWCTR store as CTR
  (setq CTR (getvar "viewctr"))
 ;Get X of CTR
  (setq CTRX (car CTR))
 ;Get Y of CTR
  (setq CTRY (cadr CTR))
 ;Get inside Viewport height
  (setq VS (getvar "viewsize"))
 ;Get XP Factor with HeighT / View Size
  (setq XP (/ HT VS))
 ;Get inside width of Viewport by
  (setq IW (* (/ VS HT) WD))
 ;Find four corners of Viewport
  (setq BL (list (- CTRX (/ IW 2)) (- CTRY (/ VS 2))))
  (setq BR (list (+ CTRX (/ IW 2)) (- CTRY (/ VS 2))))
  (setq TR (list (+ CTRX (/ IW 2)) (+ CTRY (/ VS 2))))
  (setq TL (list (- CTRX (/ IW 2)) (+ CTRY (/ VS 2))))
 ;Save current pline width
  (setq PW (getvar "plinewid"))
 ;Set Pline width to zero
  (setvar "plinewid" 0)
 ;Save current osmode
  (setq OS (getvar "osmode"))
 ;Draw pline inside border
  (command ".pline" BL BR TR TL "c")
 ;Restore pline width back
  (setvar "plinewid" PW)
 ;Restore UCS back
  (command ".ucs" "p")
 ;Restore osmode
  (setvar "osmode" OS)
 ;Clean up command prompt
 ;Go Back To Papserspace
  (command ".pspace")
) ;The End!
« Reply #1 on: August 24, 2004, 03:48:33 PM »
right after this
put this
(command "_.layer" "m" "Defpoints" "")
does that work?
ELOQUINTET
« Reply #2 on: August 24, 2004, 04:22:14 PM »
hmm sorta but it keeps me in defpoints which could be dangerous how do i get it to revert to layer previous
« Reply #3 on: August 24, 2004, 04:59:12 PM »
try this:
;PW - Save PlineWid
;OS - Save OSmode
(defun
 C:VPL
      (/ VP HT WD VN CTR CTRX CTRY VS XP IW BL BR TR TL PW OS)
;save current layer as "clay"
  (setq clay (getvar 'clayer))
;make current layer defpoints
;enter pspace
  (command ".pspace")
  (setq VP
(entget
  (car
    (entsel
             in "
    ) ;_ end of entsel
  ) ;_ end of car
) ;_ end of entget
  ) ;_ end of setq
;enter mspace
  (command ".mspace")
;set UCS to View
;Get X of CTR
;Get Y of CTR
  (setq XP (/ HT VS))
;Restore UCS back
;Restore osmode
;Restore curernt layer
  (setvar "clayer" clay)
  (command ".pspace")
) ;The End!
« Reply #4 on: August 24, 2004, 05:15:10 PM »
Quote from: eloquintet
come on Dan.............. you ain't trying very hard. There is enough code on layer manipulation in this place to choke a horse. Read man read........... :D
