Author Topic: Why does this happen? foreach foreach  (Read 1867 times)
daron
« on: March 14, 2008, 12:41:55 PM »
First off, I have this:
(setq *acad   (vlax-get-acad-object)
   doc    (vla-get-activedocument *acad)
   layers  (vla-get-layers doc)
   alist   (list "a-panel" "a-furn")
Then I create a list of layernames like so:
(vlax-for i layers
  (if (or (wcmatch (strcase (vla-get-name i) t) "rcp-*")
  (= (strcase (vla-get-name i) t) "a-head")
      (setq rcplist (append rcplist (list i)))
      (setq layernames (append layernames (list (vla-get-name i))))
This allows me to have one list for freezing and while the other thaws the layers.
What I'm having trouble with is how the next piece handles putting the list together.
(foreach i alist
  (foreach j layernames
       (if (= i (strcase j t))
    (setq below
      (append below (list (vla-item layers j)))
What I'm thinking this should do is take one item from alist (i), compare it with all the items in layernames (j) and if it finds a match append it to list "below". What's it's doing is checking (i) twice. Why?
daron
Re: Why does this happen? foreach foreach
« Reply #1 on: March 14, 2008, 02:04:54 PM »
Well, that's strange. I just rewrote that part from the inside out and it worked just fine. Uh??? Nevermind, I guess.
daron
« Reply #2 on: March 14, 2008, 02:14:54 PM »
Then again, maybe not.
daron
« Reply #3 on: March 14, 2008, 02:54:20 PM »
Well, since I'm having a conversation with myself, I'll just answer. It's works as it should. There was a variable that apparently had double information that was causing the problem.
« Reply #4 on: March 14, 2008, 04:24:37 PM »
Glad ya'll figured it out. 8-)
daron
« Reply #5 on: March 14, 2008, 04:26:58 PM »
Thanks, from all of us.
