Author Topic: having memory loss - DRAGMODE  (Read 12185 times)
whodo
« on: March 13, 2008, 11:02:54 AM »
Can anyone remember what is wrong with your cad setup if when you
go to insert a block it does not drag along with the curser. It is completely
invisible until all info is entered.
Didn't used to be this way
thanks
ron
(edited title - M-dub)
« Last Edit: March 13, 2008, 02:51:00 PM by M-dub »
M-dub
Re: having memory loss
« Reply #1 on: March 13, 2008, 11:08:11 AM »
DRAGMODE = On
Greg B
  • Tell me a Joke!
« Reply #2 on: March 13, 2008, 11:08:16 AM »
This is memory from many many years ago, but I thought that happened when you had 2 lines on top of each other.
Guest
« Reply #3 on: March 13, 2008, 11:16:49 AM »
M-dub
« Reply #4 on: March 13, 2008, 11:19:16 AM »
DRAGMODE = On
DRAGMODE = AUTO
...er uhh,  yeah. :)
I keep forgetting to take my Genko Biloba
whodo
« Reply #5 on: March 13, 2008, 12:35:34 PM »
that's what I thought but when I tried it the block was
still invisible until you finish inputing all the data, really hard
to locate it in the proper location, but I will try again maybe
a restart of autocad might help.
M-dub
« Reply #6 on: March 13, 2008, 12:45:18 PM »
Matt's right though... "On" won't help you... set it to Auto and you should be all set.
Guest
« Reply #7 on: March 13, 2008, 01:18:11 PM »
From the help file...
Controls the display of objects being dragged. This system variable has the same name as a command. Use the SETVAR command to access this system variable.
When it is on, the image of an object is displayed as you drag it to another position. With some computer configurations, dragging can be time-consuming. Use DRAGMODE to suppress dragging.
Does not display an outline of the object as you drag it
Displays the outline of the object as you drag it only if you enter drag at the command prompt after selecting the object to drag
Auto; always displays an outline of the object as you drag it
Chuck Gabriel
« Reply #8 on: March 13, 2008, 01:42:37 PM »
Are you using a built-in command to insert the block, or are you doing it with a LISP or VBA program?  You won't get the ghosting effect with the latter.
whodo
« Reply #9 on: March 13, 2008, 02:01:36 PM »
I am using the built in INsert command. The block inserts fine
but it does not drag around with you while you are looking for
an insert point. The Dragmode is set to AUTO. I may have to
try to reload Autocad as this has not been an issue before
and was working earlier this year maybe something got screwed up.
M-dub
« Reply #10 on: March 13, 2008, 02:04:12 PM »
Hmmm strange.
Did you try setting DRAGMODE to OFF and then, back to Auto?
whodo
« Reply #11 on: March 13, 2008, 02:10:50 PM »
ok people should relay all the information.
This was not on my computer but someone elses.
I told him early this morning to turn his dragmode to auto.
He said that did not work.
I was just talking with him and he says yes the visibility and
drag are working fine but he is getting everything the the command
window now and not getting the dialog box.
I told him that someone must have changed his computer to
-insert instead of insert and walked away.
I hate it with a passion when you try to help someone and he
doesn't tell you that one thing is fixed but something else has come
up.  RRRRRRRRRRRRRRRRRRRRRRRRRRRRoy.
Thanks for the help everyone
Ron
M-dub
« Reply #12 on: March 13, 2008, 02:18:19 PM »
lol
Say no more...  :lmao:
Guest
« Reply #13 on: March 13, 2008, 02:28:56 PM »
Welcome to my world!
whodo
« Reply #14 on: March 13, 2008, 02:33:28 PM »
Actually this was my world for many years. I finally got out of it about 3 years ago
and lately it has just been the odd "can you give me a hand with something or
explain something for me" I was glad to be out, "but they keep drawing me back in"
Thanks again everyone, it's nice to know I haven't forgotten everything.
