Author Topic: Tabs for open drawings - A time saver  (Read 6580 times)
Willie
  • Going nowhere slowly
« on: March 12, 2008, 10:44:15 AM »
Hi
We are using iDwgTab from www.icomtools.com.  The site is in Korean and so is the default language of iDwgTab.
Here is the direct link to download iDwgTab.
http://www.icomtools.com/bbs/bbs1/download.php?file_nm=idwgtab2.0.0.11.zip&file_db_nm=idwgtab2.0.0.11.zip
I have also attached pdf that explains how to set the default language to English.
Hope someone find this useful.
Re: Tabs for open drawings - A time saver
« Reply #1 on: March 12, 2008, 11:02:10 AM »
I use DocBar from CadWerx and yes it is a real time saver ...
Kate M
« Reply #2 on: March 12, 2008, 02:20:01 PM »
What do they do that TASKBAR doesn't? (Not being smart-aleck -- honestly curious.)
David Hall
  • Automatic Duh Generator
« Reply #3 on: March 12, 2008, 02:36:48 PM »
Ditto that, I use Taskbar
Josh Nieman
« Reply #4 on: March 12, 2008, 03:04:38 PM »
I guess I'm the stubborn caveman... I use one Autocad taskbar, and succumb to CTRL+TAB or CTRL+SHIFT+TAB
« Last Edit: March 12, 2008, 03:14:21 PM by Josh Nieman »
deegeecees
« Reply #5 on: March 12, 2008, 03:12:00 PM »
Where's the spelling nazi NOW? Huh?
Josh Nieman
« Reply #6 on: March 12, 2008, 03:14:44 PM »
 :lmao:
I tend to not care to go back and fix typos, but I figure I'll fix that one...
Crank
« Reply #7 on: March 12, 2008, 04:17:42 PM »
There are many tools out there that can do the same thing.
I use MdiTab, because it's from Autodesk.
« Reply #8 on: March 12, 2008, 07:30:26 PM »
Save all
Save all and close
Print
Sort Tabs
View
.. etc
« Reply #9 on: March 12, 2008, 07:35:32 PM »
Save all
Save all and close
Print
Sort Tabs
View
.. etc
Aside from those reasons, most add-on products can be docked within the AutoCAD window on any side of the window, and is available for all versions of AutoCAD from R2000 - R2008 .. Taskbar was introduced in R2005
Kate M
« Reply #10 on: March 13, 2008, 02:55:35 PM »
Okay, thanks.
(Although SAVEALL & CLOSEALL are available in Express Tools... ;))
phoulx
« Reply #11 on: March 26, 2008, 08:09:47 AM »
As far as Saveall goes, do any of these work differently than Express Tools?  We can't use the Express Tools version as it ignores the "Save as earlier version" setting and plenty of our clients are on earlier versions.
« Reply #12 on: March 26, 2008, 08:18:25 AM »
Hmmmm ..  I dunno ... I have never tried that  .. I suppose I could set my drawing type to a previous version and give it a go.
Guest
« Reply #13 on: March 26, 2008, 08:20:17 AM »
This is where eTransmit comes in REAAAAALLLY handy.  Just set up a transmittal to save as 2000 or 2004, grab all of the files, push a button and *poof* you've got your drawings (and all supporting drawings) saved as an earlier version.
jonesy
  • SuperMod
« Reply #14 on: March 26, 2008, 09:43:05 AM »
Since I was upgraded last week, I have been trying DwgMan by CAELink... so far it seems to do what I need
