Author Topic: roof making lisp  (Read 2551 times)
dussla
roof making lisp
« on: March 12, 2008, 01:44:27 AM »
hello  , friend
i will ask again , sorry many asks and helps  ~
if you see my attatched image , you can see my wanted routine
if i select   a , b ,  c  and put  distance(d)  value    , then  routine  will draw  next image
pls can you understand ~?
thank you always ~
« Last Edit: March 13, 2008, 12:07:59 AM by dussla »
DEVITG
Re: roof making lisp
« Reply #1 on: March 12, 2008, 10:07:49 PM »
How about if you upload a true  ACAD DWG???
« Reply #2 on: March 12, 2008, 10:18:56 PM »
Let us see what you've done so far ...
dussla
« Reply #3 on: March 13, 2008, 12:08:15 AM »
PLS , I ADDED  DWG FILE
« Reply #4 on: March 13, 2008, 03:09:35 PM »
I'll get you started but you will need to complete any modifications to the lisp.
(defun c:RoofCap (/ p1 p2 p3 dis ofs an1 an2 an3 p1a p1b p2a p2c)
  (prompt "\nPick 3 points for roof. End, Peak, End.")
  (if (and
        (setq p1 (getpoint "\nPick 1st of 3 points."))
        (setq p2 (getpoint "\nPick 2nd of 3 points."))
        (setq p3 (getpoint "\nPick 3rd of 3 points."))
        (setq dis (getdist "\nEnter Length of Cap."))
      (setq ofs 20. ; offset from roof line
            p1a (polar p2 (angle p2 p1) dis)
            p2a (polar p2 (angle p2 p3) dis)
            an1 (+ (angle p2 p1) (/ pi 2.))
            an2 (+ (angle p2 p1) (* pi 1.5))
      (if (> (distance p3 (polar p1a an2 ofs)) (distance p3 (polar p1a an1 ofs)))
        (setq an1 an2)
      (setq an2 (+ (angle p2 p3) (/ pi 2.))
            an3 (+ (angle p2 p3) (* pi 1.5))
      (if (> (distance p1 (polar p1a an3 ofs)) (distance p1 (polar p1a an2 ofs)))
        (setq an2 an3)
      (setq p1b (polar p1a an1 ofs)
            p2c (polar p2a an2 ofs)
            int (inters p1b (polar p1b (angle p1 p2) 10)
                        p2c (polar p2c (angle p3 p2) 10) nil)
      (command "_pline" "_non" p1a "_non" p2 "_non" p2a "_non"
               p2c "_non" int "_non" p1b "_CLose")
dussla
« Reply #5 on: March 13, 2008, 08:30:12 PM »
really , really  thank you cab  always
routine is very good ~
alanjt
  • Standby for witty remark...
« Reply #6 on: March 14, 2008, 10:18:35 AM »
yoink!
Dropbox
