Author Topic: Saving down with Objectdbx  (Read 6164 times)
OcCad
« on: March 10, 2008, 06:47:50 PM »
I'm modifying multiple drawing with odbx but some files were becoming unreadable for clients. Normally I save down to 2004 from 2008 but in odbx the default saveas seems to be 2007. How do I do a saveas savedown to 2004? Or convert to 2004?
Re: Saving down with Objectdbx
« Reply #1 on: March 10, 2008, 10:54:52 PM »
Have you tried this.
It will convert multiple files.
http://www.theswamp.org/index.php?topic=8279.msg161421#msg161421
I've reached the age where the happy hour is a nap. (°Ώ°)
OcCad
« Reply #2 on: March 10, 2008, 10:59:11 PM »
Thats the thing though. i dont want to have to use dwgconvert. I would rather do it in the lisp. Right now the routine is causing the problem by vla-saveas to 2007. is there a way to tell it to save to 2004 version?
« Reply #3 on: March 10, 2008, 11:02:40 PM »
OcCad
« Reply #4 on: March 10, 2008, 11:11:59 PM »
I dont understand. that post says the vla-save method doesnt work in odbx. But I'm looking to use vla-saveas but to an older format
« Reply #5 on: March 10, 2008, 11:27:03 PM »
True, you can't.
AKAIK ... You can't specify the format. The SaveAs method for documents opened via ObjectDBX takes two arguments, the first (mandatory) is a string representing the file path and name. The second (optional) is a variant allowing one to encrypt and digitally sign the drawing. I personally haven't used the latter and can't say I'm an advocate.
Sorry to confirm the bad news.
(Discussion based on 2008).
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
FengK
« Reply #6 on: March 11, 2008, 03:49:53 AM »
Do you have to use ObjectDBX? Are you processing hundreds/thousands of drawings?
« Reply #7 on: March 11, 2008, 04:30:01 AM »
That's the thing though. i dint want to have to use dwgconvert. I would rather do it in the lisp. Right now the routine is causing the problem by vla-saveas to 2007. is there a way to tell it to save to 2004 version?
I'm sure you have your reasons for not using dwgconvert, but I can't immediately think of one ... care to share the reasons ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: March 11, 2008, 06:49:00 AM »
Don’t know if this will help you but here is an ARX routine that might do the trick.
(saveas2004 "c:\\1.dwg" "c:\\2.dwg")
(saveas2000 "c:\\1.dwg" "c:\\2.dwg")
Joe Burke
« Reply #9 on: March 11, 2008, 08:03:44 AM »
Daniel,
That's interesting. Where did it come from? Google search finds no mention of it elsewhere.
A few quick tests indicate it *may* be a solution for saving down an ODBX document. After the document is released, I think you would have to give the file a unique saveas name. Then delete the original/source file and rename the new file the same as the original. IOW, it does not allow this (saveas2000 "c:\\example.dwg" "c:\\example.dwg").
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: March 11, 2008, 08:13:12 AM »
...Where did it come from?....
I just wrote it, :-o
 my tests also show that it can’t be the same filename  :|
« Reply #11 on: March 11, 2008, 08:14:14 AM »
Nice, I'll have to try that Daniel. Like Joe said, where did it come from? Is the source code available? I'd be wary of building a solution around it without knowing something about it's origins and future. Nonetheless has promise. :)
Bah, ya snuck in as I was posting, I'll leave it verbatim; peace. :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: March 11, 2008, 08:36:55 AM »
This is in my open source project for lispers, there is also a few other goodies in here, I will post this in the "Show your stuff" area in a while
Arx code.
  static int ads_saveas2004(void)
    Acad::ErrorStatus es;
    struct resbuf *pArgs =acedGetArgs () ;
    if (pArgs == NULL || pArgs->restype != RTSTR )
      return RSERR;
    if (pArgs->restype != RTSTR )
      return RSERR;
    CString infile = pArgs->resval.rstring;
    if ((pArgs = pArgs->rbnext) == NULL || pArgs->restype != RTSTR )
      return RSERR;
    CString outfile = pArgs->resval.rstring;
    std::auto_ptr<AcDbDatabase> pDb(new AcDbDatabase(Adesk::kFalse));
    es = pDb->readDwgFile(infile);
    if(es != Acad::eOk)
      return es;
    es = acdbSaveAs2004(pDb.get(),outfile);
    if(es != Acad::eOk)
       return es;
    acedRetT();
    return (RSRSLT) ;
  static int ads_saveas2000(void)
      return RSERR;
      return RSERR;
      return RSERR;
    if(es != Acad::eOk)
      return es;
    es = acdbSaveAs2000(pDb.get(),outfile);
    if(es != Acad::eOk)
       return es;
    acedRetT();
    return (RSRSLT) ;
« Last Edit: March 11, 2008, 08:42:59 AM by Daniel »
« Reply #13 on: March 11, 2008, 08:39:36 AM »
This in my open source project for lispers, there is also a few other goodies in here, I will post this in the "Show your stuff" area in a while ...
Thanks Daniel, that's be great.
Guest
« Reply #14 on: March 11, 2008, 08:42:09 AM »
AutoCAD 2008 has a new command called AECTOACAD that will allow you to save in a lower version (back to R14).  Might be of some use?!?
