I'm trying to set up the import page setups button I have for 2004 on a 2000 system and I keep having this problem where it shows the correct plot style, but when I do a preview or just print without doing the preview, it doesn't actually USE the plot style. In other words, I'm trying to import a page setup that uses a plot style called B-Mono.ctb. It appears to import fine, with no error messages, but after I do a Full Preview and exit back to the Plot dialog box, the plot style reverts back to None. If I manually select B-Mono, it works fine.
I've mucked around with every setting I can think of, but it keeps doing this! Can someone please help?!
Thank-you VERY Much!
Mike
