Author Topic: a deliberate faux pas....honestly  (Read 3424 times)
Big G
« on: March 02, 2008, 11:03:26 PM »
cad crashed...i opened the xref autosave (not realising that the autosave was from last week) and saved over my drawing (containing todays work).....BUT by some miracle means i managed to open another drawing that crashed too and has the 'correct' xref file....
question.
The xref is still pathed to the (saved over) xref file but has the correct data...is there a way i can explode or export or generally split the (correct) xref, subsequently  ending up with it not being xref'd into the dwg?
clear as mud??!!??  :ugly:
to summise...
cad crashed...opened 2 files which were open before the crash and managed to overwrite the xref with last weeks autosave...meanwhile in the other drawing....the xref has read from the file before i overwrote it..and i need to use that xref again...is there a way i can get it back.....
the .bak and .sv$ are usless.....
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
Dinosaur
Re: a deliberate faux pas....honestly
« Reply #1 on: March 02, 2008, 11:11:20 PM »
I would think that if the xref is correct in that one file, it exists intact somewhere in the search path of that file.  Open the file with the good xref and check what file is being referenced.  You should be able to open and save that file for use with the other file as well.
Big G
« Reply #2 on: March 02, 2008, 11:21:17 PM »
dino...Ive saved over the xref with last weeks one....the open drawing only has the correct xref as i havent updated it yet.....(which is the one prior to me overwriting it)
Dinosaur
« Reply #3 on: March 02, 2008, 11:27:19 PM »
bad news that . . . right now that drawing only exists in you computer's memory.  I think you might still be able to bind the xref to the drawing and save the whole thing as a new file, but it will be quite a mess to work with.
Big G
« Reply #4 on: March 02, 2008, 11:31:52 PM »
already been tryin that dino....it wants me to update it before it will let me bind it....even a ctrl-c paste into new drawing repaths it to the wrong xref....dagnammit!!
just wondering if anyone had a 'burst' xref routine? to explode the xref'd entities back into lines/arcs etc...??
« Reply #5 on: March 02, 2008, 11:33:31 PM »
Hang on ... I'll try to code something up ...
Big G
« Reply #6 on: March 02, 2008, 11:35:33 PM »
bork bork bork!! eets ze sveedish zhef!!
Dinosaur
« Reply #7 on: March 02, 2008, 11:53:39 PM »
it may not make any difference at all, but you could rename that referenced file (might not be a bad idea anyway or at least copy it somewhere) and see if AutoCAD still demands an update
« Reply #8 on: March 03, 2008, 12:42:18 AM »
<code deleted>
« Last Edit: March 03, 2008, 08:17:01 AM by MP »
Big G
« Reply #9 on: March 03, 2008, 12:57:09 AM »
as wayne and garth once said "We're not worthy!!!"
awesome job...one xref redrawn and ones derriere saved for another day  8-) 8-)
« Reply #10 on: March 03, 2008, 07:26:58 AM »
Glad to hear you were able to recover the xref data. That code has now been retired. Cheers.
Bob Wahr
« Reply #11 on: March 03, 2008, 08:11:10 AM »
A wise man once said
Separate your ego from your code. Your code is not you <snip>. I'm about to disappoint you but we don't like you because of your code. We like you because you share your code, your expertise, your perspective, your triumphs and your failures, your life.
If you happen to post some code and it's less than perfect oh well, we don't think any less of you as a person. More importantly, letting less than perfect posts exist for perpetuity demonstrates humility as well as personal growth - look how well I code now compared to a year ago, woot.
Are these bad things?
« Reply #12 on: March 03, 2008, 08:16:35 AM »
I deleted that code because it could be used incorrectly, I have zero interest in supporting it or (added) discussing it.
I should have sent the code to the poster privately.
I'll not make that mistake again.
« Last Edit: March 03, 2008, 11:45:05 AM by MP »
Bob Wahr
« Reply #13 on: March 03, 2008, 08:38:39 AM »
just sayin'
Josh Nieman
« Reply #14 on: March 03, 2008, 09:08:01 AM »
just sayin'
Glad someone else said what I was thinkin'
