Author Topic: need help finding my error  (Read 2525 times)
ELOQUINTET
« on: February 28, 2008, 11:35:55 AM »
hey guys i was just modifying the dimnote routine and had it working until i decided to abbreviate it from dimnote to dn. i also renamed the lisp and dcl files and now it gives me this message. i know it is something small but can't figure out what i didn't change?
cannot find definition for dialog dn
;Tip1566A:  DIMNOTE.LSP   Dimension Notes   (c)1999, Mike Lapinski
(defun DN_SHOWNOTE (/ LNUM LNOTE)
  (set_tile "error" "")
  (setq LNUM  (get_tile "lb_notes")
        LNOTE (nth (atoi LNUM) DM_NOTES)
  ) ;_ end of setq
  (set_tile "eb_note" LNOTE)
) ;_ end of defun
;; Function: DN_PlaceNote
;; Purpose:  If valid note is input, close dialog box
(defun DN_PLACENOTE ()
  (setq DN_MODIFIER (strcase (get_tile "eb_note")))
  (if (= DN_MODIFIER " ")
    (set_tile "error" "Invalid note string")
    (done_dialog 1)
  ) ;_ end of if
) ;_ end of defun
;; Function: DN_AppendNote
;; Purpose:  Append note to selected dimension entity
(defun DN_APPENDDIM (VAL PLACEMENT / ENT DVAL)
  (setq ENT (car (entsel "\nSelect dimension for note: ")))
  (while (/= "DIMENSION" (cdr (assoc 0 (entget ENT))))
    (princ "\nSelected entity is not a DIMENSION.")
  ) ;while
  (setq ENT  (entget ENT)
        DVAL (cdr (assoc 1 ENT))
  ) ;_ end of setq
  (if (= DVAL "")
    (setq DVAL "<>")
  ) ;_ end of if
  (if (= PLACEMENT 1) ;above line
    (setq VAL (strcat DVAL " " VAL))
      (if (wcmatch DVAL "*\\X*")
        (setq VAL (strcat DVAL "\\P" VAL))
        (setq VAL (strcat DVAL "\\X" VAL))
      ) ;_ end of if
    ) ;_ end of progn
  ) ;_ end of if
  (entmod (subst (cons 1 VAL) (assoc 1 ENT) ENT))
) ;_ end of defun
;; Main Function - Dimension NOTE
(defun C:DN (/ DCL_ID DM_NOTES DN_ABOVE)
  (setq DCL_ID (load_dialog "DN.dcl"))
  (if (not (new_dialog "DN" DCL_ID))
    (exit)
  ) ;_ end of if
  (setq DM_NOTES '("(NOM.)" "(SHELF)" "(TOP)" "(OVERALL)" "(EXACT)"
        DN_ABOVE 1
  ) ;_ end of setq
  (set_tile "eb_note" "(OVERALL)")
  (set_tile "dn_above" "1") ; Set as default
  (start_list "lb_notes")
  (mapcar 'add_list DM_NOTES)
  (end_list)
  (set_tile "lb_notes" "7")
  (action_tile "lb_notes" "(DN_ShowNote)")
  (action_tile "dn_above" "(setq dn_above 1)")
  (action_tile "accept" "(DN_PlaceNote)")
  (action_tile "cancel" "(done_dialog 0)")
  (if (eq (start_dialog) 1)
    (DN_APPENDDIM DN_MODIFIER DN_ABOVE)
  ) ;_ end of if
  (unload_dialog DCL_ID)
) ;_ end of defun
(princ "Load by typing  DN  ")
ELOQUINTET
Re: need help finding my error
« Reply #1 on: February 28, 2008, 01:50:47 PM »
Hmmm all I did was change the occurances of DN back to Dimnote and it's working again but I don't understand why I can't change this and the filenames to DN and have it work?
Changed it back to this:
(defun C:Dimnote (/ DCL_ID DM_NOTES DN_ABOVE)
  (setq DCL_ID (load_dialog "Dimnote.dcl"))
  (if (not (new_dialog "dimnote" DCL_ID))
daron
« Reply #2 on: February 28, 2008, 01:51:48 PM »
Did you change the name of the .dcl file as well?
ELOQUINTET
« Reply #3 on: February 28, 2008, 03:01:11 PM »
i did change the dcl name daron. this is not a big deal i just wanted to understand the logic of the whole thing.
daron
« Reply #4 on: February 28, 2008, 03:15:11 PM »
There must be some internals you're missing then. I haven't worked with dcls in so long, I don't even know where to begin looking.
GDF
« Reply #5 on: February 28, 2008, 03:38:52 PM »
Did you change the name "dimnote" within the dcl file?
« Reply #6 on: February 28, 2008, 04:43:39 PM »
^^ Has my vote!
ELOQUINTET
« Reply #7 on: February 29, 2008, 10:25:08 AM »
we have a winner. changing the name inside of the dcl did the trick. i didn't know it mattered but apparently it's not a comment like in the lisp, good to know. thanks for your help
