Author Topic: Display viewport scale lisp  (Read 5712 times)
ELOQUINTET
« on: February 26, 2008, 04:41:26 PM »
Hey guys i thought i had seen a lisp which would do this a long time ago but now that i need it I can't find it. I actually found this routine a minute ago but it's not working for me. It says it is supposed to put the scale in text in the drawing but when i type vpscale it shows me the scale at command line and when i type vps i see it creates the layer from the routine but halt. Since I am now working in 2002 urrrrgrh I cannot use fields so this is my only option. Does anyone know what's wrong with this routine or have somethings else I could steal.  :evil:
;* Permission to use copy or modify this
;* program is hereby granted, and is supplied
;* on an "as is" basis.
;* Designed by SYD Derbyshire - dec 03
;* C:VPSCALE Adds scale annotation in text style TITLE
;* (font Swiss 721 Black Extended BT) 3.5mm high, in layer VP-TEXT,
;* 7.5mm below paper space viewport, centred to viewport.
;* User can then edit to add viewport annotation.
(defun *error* ()
(terpri)
;*  ------------------------------------------------------------  SUBROUTINE  ------------------------------------------------------------
(defun MTWINDOW (/);---declare subroutine function with no arguments or global variables
(setq xM (car mid#vpbaseline));---get X value of midpoint
(setq yM (cadr mid#vpbaseline));---get Y value of midpoint
(setq TLx (- xM 125));---assign X value to Top Left point variable
(setq TLy yM);---assign Y value to Top Left point variable
(setq BRx (+ xM 125));---assign X value to Bottom Left point variable
(setq BRy (- yM 15));---assign Y value to Bottom Left variable
(setq TL (list TLx TLy));---construct Top Left point of box
(setq BR (list BRx BRy));---construct Bottom Right point of box
);---end function
;*  -----------------------------------------------------------  MAIN PROGRAM  -----------------------------------------------------------
(defun C:VPS (/ osm oldsty oldht vpobj etxt vpscale#denom vpscale#num  vpscale#factor vpscale#string vpscale
mid#vpbaseline xM yM TLx TLy BRx BRy TL BR);---declare no arguments, and global variable list
;---Test for Model Space
(if (= (getvar "TILEMODE") 1)
(alert "Not allowed in Model Space")(exit);---issue message in Alert Box if in Model Space
);---end progn
);---end if
(setvar "CMDECHO" 0);---prevent command line echo of commands called from program
(setq osm (getvar "OSMODE"));---store existing object snap values
(setq oldsty (getvar "TEXTSTYLE"));---store existing text style
(setq oldlay (getvar "CLAYER"));---store existing layer name
(setq oldht (getvar "TEXTSIZE"));---store existing text height
(setvar "OSMODE" 0);---set object snap to zero
(setvar "TEXTSIZE" 3.5);---set text height to 3.5
(command "-STYLE" "TITLE" "swissek.ttf" "0" "0.8" "" "" "");---define text style and make current
(command "-LAYER" "M" "VP-TEXT" "C" "7" "" "LW" 0.25 "" "PS" "mono" "" "");---make new layer and set current
;---LOOP to ensure selection of VIEWPORT object only
(while
(not (= (cdr (assoc 0 (entget (car (setq vpobj (entsel "\nSelect Viewport to annotate: ")))))) "VIEWPORT"))
(prompt "\nSelect a Viewport ONLY please: ")
);---end while loop
(setq etxt (entget (car vpobj)));---store symbol table for object selected
(setq vpscale#denom (cdr (assoc 41 etxt)));---base scale factor
(setq vpscale#num (cdr (assoc 45 etxt)));---scale factor value
(setq vpscale# (/ vpscale#num vpscale#denom));---returns absolute viewport scale as integer
(setq vpscale#factor vpscale#);---record absolute viewport scale
(if (< vpscale#factor 1)(setq vpscale#factor (/ 1 vpscale#factor)));---sets viewport scale to real
(setq vpscale#string (rtos vpscale#factor));---returns string value of viewport scale
;---Test absolute scale factor value and set string to reflect scale value correctly
((< vpscale# 1)(setq vpscale (strcat "SCALE " vpscale#string ":1")))
;((> (- vpscale# (fix vpscale#)) 0)(setq vpscale "N.T.S."))
((>= vpscale# 1)(setq vpscale (strcat "SCALE 1:" vpscale#string)))
(setvar "OSMODE" 2);---set object snap to MIDPOINT
(setq mid#vpbaseline (getpoint "\nSelect midpoint Viewport base line: "));---user select midpoint of viewport baseline
(terpri)
(setvar "OSMODE" 0);---delimit object snap
(MTWINDOW);---subroutine calculation of MTEXT window points see SUBROUTINE
(command "-MTEXT" TL "J" "MC" BR vpscale "")
;---RESET environment
(setvar "OSMODE" osm)
(setvar "TEXTSTYLE" oldsty)
(setvar "CLAYER" oldlay)
(setvar "TEXTSIZE" oldht)
);---end function
ELOQUINTET
Re: Display viewport scale lisp
« Reply #1 on: February 26, 2008, 05:30:55 PM »
i was playing with this routine and it works although the placement of the label is a little strange but as I'm working with it I realize that what I actually need is a routine that would check to see if the viewport scale matches the scale indicated by the drawing title which is an attributed block. The tricky thing is that sometimes when i scale viewports i do it in architectural units (1-1/2"=1'-0" and other times in i guess civil? 1:8) so the routine would need to read both. Is this an easy thing to do or no. Maaaan I can't wait until they upgrade here ugggggh
« Reply #2 on: February 27, 2008, 06:35:53 AM »
Dan why use lisp when you could do this by attaching a FIELD to your viewport that would show your scale?
FIELD>>>Object>>>Viewport>>>Select from a plethora of information regarding the viewport the Field is attached to.
Steve(UK)
« Reply #3 on: February 27, 2008, 07:12:01 AM »
Probably because he's
« Reply #4 on: February 27, 2008, 07:30:45 AM »
OK, that s'plains it well enough.
« Reply #5 on: February 27, 2008, 09:09:06 AM »
. The tricky thing is that sometimes when i scale viewports i do it in architectural units (1-1/2"=1'-0" and other times in i guess civil? 1:8 ) so the routine would need to read both. Is this an easy thing to do or no. Maaaan I can't wait until they upgrade here ugggggh
http://www.theswamp.org/index.php?topic=18143.msg258985#msg258985
« Last Edit: February 27, 2008, 10:23:15 AM by CAB »
ELOQUINTET
« Reply #6 on: February 27, 2008, 09:41:15 AM »
cab i don't have a problem with creating the viewport. my problem is checking to see if the scale noted in the title matches the scale of the viewport.
« Reply #7 on: February 27, 2008, 09:53:07 AM »
That lisp shows you how to process the different scale notations.
ELOQUINTET
« Reply #8 on: February 27, 2008, 10:19:53 AM »
alright i'll take a closer look when i get a minute
