Author Topic: Inserting a drawing with a lisp  (Read 1942 times)
Luke
« on: February 26, 2008, 09:02:52 AM »
I have a lisp file that is in my startup suite.  It load all my support lisps and now I think I want to make it load some support drawings.  Having trouble with that.
(command "insert" "LCC_Annotation.dwg")  :|
Re: Inserting a drawing with a lisp
« Reply #1 on: February 26, 2008, 09:26:33 AM »
Short on time, but you should not use COMMAND in the start up.
Else look at this:
(setq sysattdia (getvar "ATTDIA"))
(setq sysattreq (getvar "ATTREQ"))
(setq systxteva (getvar "TEXTEVAL"))
(setvar "ATTDIA" 0)
(setvar "ATTREQ" 0)
(setvar "TEXTEVAL" 0)
    (command "-insert" bname "0,0,0" "1.0" "" "0.0" )
(setvar "ATTDIA"   sysattdia)
(setvar "ATTREQ"   sysattreq)
(setvar "TEXTEVAL" systxteva)
rkmcswain
« Reply #2 on: February 27, 2008, 08:22:12 AM »
As CAB says, the (command) function will generally not work in a startup lisp.
It needs to be defined in the S::STARTUP function.
Details on all of this are in the Customization Guide
« Reply #3 on: February 27, 2008, 08:31:35 AM »
why not insert that dwg into the appropriate DWT?
Luke
« Reply #4 on: February 27, 2008, 11:30:35 AM »
I can and will be putting it in my template.
However, I want it to be availabe for use in old drawings.  My template is brand new and only use when starting a new drawing.  But if going into an existing drawing I want this LCC_Annotation.dwg to load into the old drawings.
