General coordinate parsing for commandline
(1/1)
SEANT:
I’m attempting a UI addition to make CAD work on a laptop less irritating.
The general hope is to reduce the need for a number pad (not available on my laptop) by utilizing the Screen Menus. The “cumulative” approach I have works well enough for single inputs, i.e., Circle radius, Offset amount, etc.
It is the coordinate input - 3.5,1.5 - for example, that is giving me trouble. Are there any suggestions for concatenating this info, like I’ve attempted in the lines labeled [Comma ] and [EnterXY]
This is what I currently have:
--- Code: ---**SUMPAD 3
[Comma ](setvar 'USERR4 (getvar 'USERR5))(setvar 'USERR5 0.0)^Z
[EnterXY]eval(getvar 'USERR4),eval(getvar 'USERR5);
[1/32 ](setvar 'USERR5 (+(getvar 'USERR5) 0.03125))^Z
[1/16 ](setvar 'USERR5 (+(getvar 'USERR5) 0.0625))^Z
[1/8 ](setvar 'USERR5 (+(getvar 'USERR5) 0.125))^Z
[1/4 ](setvar 'USERR5 (+(getvar 'USERR5) 0.25))^Z
[1/2 ](setvar 'USERR5 (+(getvar 'USERR5) 0.5))^Z
[Submit ](getvar 'USERR5);
[1 ](setvar 'USERR5 (+(getvar 'USERR5) 1.0))^Z
[2 ](setvar 'USERR5 (+(getvar 'USERR5) 2.0))^Z
[4 ](setvar 'USERR5 (+(getvar 'USERR5) 4.0))^Z
[5 ](setvar 'USERR5 (+(getvar 'USERR5) 5.0))^Z
[10 ](setvar 'USERR5 (+(getvar 'USERR5) 10.0))^Z
[20 ](setvar 'USERR5 (+(getvar 'USERR5) 20.0))^Z
[40 ](setvar 'USERR5 (+(getvar 'USERR5) 40.0))^Z
[50 ](setvar 'USERR5 (+(getvar 'USERR5) 50.0))^Z
[100 ](setvar 'USERR5 (+(getvar 'USERR5) 100.0))^Z
[200 ](setvar 'USERR5 (+(getvar 'USERR5) 200.0))^Z
[400 ](setvar 'USERR5 (+(getvar 'USERR5) 400.0))^Z
[500 ](setvar 'USERR5 (+(getvar 'USERR5) 500.0))^Z
--- End code ---
A call line for the screen menu pane would look like:
--- Code: ---[SumPad ](setvar 'USERR5 0.0)(setvar 'USERR4 0.0)$S=Sumpad
--- End code ---
Navigation
[0] Message Index
Go to full version
