Author Topic: Move objects in a scale fashion  (Read 5459 times)
« on: February 21, 2008, 01:40:06 PM »
I don't know how possible this is to move objects in a scale fashion.  I tried some simple ways, but they didn't work.  Then I thought about trying to do it with a transformation matrix, but I'm not that good with them, and I couldn't think of a way.
The reason is because I have drawings that were setup one way (not the way we want them to be), and I have to change them to the correct setup.  All the notes are in paper space, and when I redo the setup the scale of the viewports are going to change, and I want an automatic way to move the notes to the correct locations.
Thanks for any tips.
M-dub
Re: Move objects in a scale fashion
« Reply #1 on: February 21, 2008, 02:04:22 PM »
Would this have to be lisp?  Could it not be done with a script?  I suppose it would mean that all drawings would have to be located at the same origins and be the same sizes, etc....
Just wonderin'... I can do script!  :)
« Reply #2 on: February 21, 2008, 02:37:10 PM »
Maybe this?
Get the center of the vp in paper space = [CVP]
Calc distance ratio to move, (/ New_scale old_scale) = [DR]
Calc new text point, (polar CVP (angle CVP old_pt) (* (distance CVP old_pt) DR))
« Reply #3 on: February 21, 2008, 02:56:10 PM »
How would you do it in script?  If it can be done in script, then it can be done in lisp.
Maybe this?
I tried something similar.  I got a base point, then I got the center of the bounding box of each object.  I then Move the objects the ratio of the difference in scales.  They were close, but not exact.  Here was my code.
(defun c:MoveScale (/ ActDoc ScFac ll ur MidPt)
    (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (vla-EndUndoMark ActDoc)
    (vla-StartUndoMark ActDoc)
            (setq BsPt (getpoint "\n Select base point for move/scale operation: "))
            (setq ScFac (getreal "\n Enter scale factor: "))
            (setq BsPt (trans BsPt 1 0))
            (ssget)
        (vlax-for obj (vla-get-ActiveSelectionSet ActDoc)
            (vla-GetBoundingBox obj 'll 'ur)
            (setq MidPt
                (mapcar
                    '(lambda (a b)
                            (+ a b)
                            2.
                    (safearray-value ll)
                    (safearray-value ur)
            (vlax-invoke obj 'Move MidPt (polar MidPt (angle MidPt BsPt) (* ScFac (distance MidPt BsPt))))
« Reply #4 on: February 22, 2008, 11:06:27 AM »
This is my take on the situation.
The problem is the bounding box.
Use this code with a leader & text. Select the VP center & then the point of the leader.
The move is correct. You would need to move objects by type of object and when there
is an association like a leader you would need to move them as a pair.
(defun c:myMove (/ bspt scfac ss objpt)
  (setq ScFac (getdist "\n Enter scale factor: "))
  (setq ss (ssget))
  (setq ObjPt (getpoint "\n Select base point of object: "))
  (command "move"
           ss
           ObjPt
           (polar ObjPt (angle ObjPt BSPt) (* (distance ObjPt BSPt) ScFac))
« Reply #5 on: February 22, 2008, 11:27:18 AM »
  (setq ss (ssget))
  (command "move"
           ss
           ObjPt
It does work, but it is not generic enough.  The code should be able to move each object the way the scale command moves them.  Another problem is that some, if not all/most, of the leaders and text are not connected to each other.
« Reply #6 on: February 22, 2008, 12:37:17 PM »
I just don't see a way to move a leader & text without moving them together.
Maybe you will need to process each leader and acquire the nearest text to the end of the leader.
Very messy but the only way I see. :-(
« Reply #7 on: February 22, 2008, 12:44:47 PM »
Yea, and if that is the only way, then no need to try and automate it, as just moving each object(s) will be about the same amount of effort.  Thanks for trying.   :-)
M-dub
« Reply #8 on: February 22, 2008, 01:01:20 PM »
I guess I was asking about script, wondering how uniform these drawings are?  Just wondering if you could use coordinates to select your entities, move them etc.  That is likely the only way scripts would be useful.
« Reply #9 on: February 22, 2008, 01:11:09 PM »
Yea.  I don't think a script will do it, but I was hoping you had some mad script skills that would just wow me.  :-)
I think it has to be a transformation matrix operation, but I'm not sure if it can be done.  I guess this will be one of those pet projects that will evolve over time.
M-dub
« Reply #10 on: February 22, 2008, 01:15:57 PM »
I might have been able to get a Wow out of you, but I don't think I quite grasped the scope completely.  :)
« Reply #11 on: February 22, 2008, 01:35:14 PM »
You can try this:
http://www.theswamp.org/index.php?topic=8916.msg114542#msg114542
but I think you will get the same results.
« Reply #12 on: February 22, 2008, 02:27:02 PM »
You can try this:
Yup.  I think I'm out of luck.  I will see what I can come up with when I have time, but no time to play right now, w*rk calls.
Thanks for trying Guys.
Crank
« Reply #13 on: February 23, 2008, 12:08:22 PM »
I don't know how possible this is to move objects in a scale fashion.  I tried some simple ways, but they didn't work.  [...]
Have you tried CHSPACE ?
  • Use CHSPACE to move the annotations to MSPACE
  • Scale objects and change the scale of the viewport
  • Use CHSPACE to place the annotations in the layout again.
« Reply #14 on: February 23, 2008, 01:01:58 PM »
The problem Tim is having is that for objects to maintain there relative insertion point they must be moved based on that insertion point.
In the case of a leader & it's text the relevant point is the arrow head point and that group must be moved bases on that point if the leader & text are to stay aligned & the arrow head maintain it's relation to the new VP.
You see in this picture the only vector that produces the correct alignment point is the one to the leader arrow.
