Move objects in a scale fashion
T.Willey:
I don't know how possible this is to move objects in a scale fashion. I tried some simple ways, but they didn't work. Then I thought about trying to do it with a transformation matrix, but I'm not that good with them, and I couldn't think of a way.
The reason is because I have drawings that were setup one way (not the way we want them to be), and I have to change them to the correct setup. All the notes are in paper space, and when I redo the setup the scale of the viewports are going to change, and I want an automatic way to move the notes to the correct locations.
Thanks for any tips.
M-dub:
Would this have to be lisp? Could it not be done with a script? I suppose it would mean that all drawings would have to be located at the same origins and be the same sizes, etc....
Just wonderin'... I can do script! :)
CAB:
Maybe this?
Get the center of the vp in paper space = [CVP]
Calc distance ratio to move, (/ New_scale old_scale) = [DR]
Calc new text point, (polar CVP (angle CVP old_pt) (* (distance CVP old_pt) DR))
T.Willey:
--- Quote from: M-dub on February 21, 2008, 02:04:22 PM ---Would this have to be lisp? Could it not be done with a script? I suppose it would mean that all drawings would have to be located at the same origins and be the same sizes, etc....
--- End quote ---
How would you do it in script? If it can be done in script, then it can be done in lisp.
--- Quote from: CAB on February 21, 2008, 02:37:10 PM ---Maybe this?
--- End quote ---
I tried something similar. I got a base point, then I got the center of the bounding box of each object. I then Move the objects the ratio of the difference in scales. They were close, but not exact. Here was my code.
--- Code: ---(defun c:MoveScale (/ ActDoc ScFac ll ur MidPt)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-EndUndoMark ActDoc)
(vla-StartUndoMark ActDoc)
(and
(setq BsPt (getpoint "\n Select base point for move/scale operation: "))
(setq ScFac (getreal "\n Enter scale factor: "))
(setq BsPt (trans BsPt 1 0))
(ssget)
(vlax-for obj (vla-get-ActiveSelectionSet ActDoc)
(vla-GetBoundingBox obj 'll 'ur)
(setq MidPt
(mapcar
'(lambda (a b)
(+ a b)
2.
(safearray-value ll)
(safearray-value ur)
(vlax-invoke obj 'Move MidPt (polar MidPt (angle MidPt BsPt) (* ScFac (distance MidPt BsPt))))
--- End code ---
CAB:
This is my take on the situation.
The problem is the bounding box.
Use this code with a leader & text. Select the VP center & then the point of the leader.
The move is correct. You would need to move objects by type of object and when there
is an association like a leader you would need to move them as a pair.
--- Code: ---(defun c:myMove (/ bspt scfac ss objpt)
(setq ScFac (getdist "\n Enter scale factor: "))
(setq ss (ssget))
(setq ObjPt (getpoint "\n Select base point of object: "))
(command "move"
ss
ObjPt
(polar ObjPt (angle ObjPt BSPt) (* (distance ObjPt BSPt) ScFac))
--- End code ---
Navigation
[0] Message Index
[#] Next page
Go to full version
