Here is a flex duct routine I located. I need for it to prompt me for size of duct such as 10", or 8", etc. How would that parameter be placed within the routine?
Flex.lsp
Version history
3.2 2003/03/04 Localized variable NextPointFactor. Added variable for default curve type
and layer color. Curve type was localized for the PEdit command.
3.1 2002/06/28 Anniversary (wedding) release. Update usage permissions.
3.0 2000/05/18 General use release.
2.1 1994/03/31 Added code for correct Release 12 operation.
2.0 1992/06/28 Major revision to support defaults & splined polylines.
1.0 1989/09/09 Initial release.
Draw a zig-zag polyline. Used for flexible ductwork.
Copyright ©, 1989-2003, by R. Robert Bell.
3914 E Bridgeport Ave
Spokane WA 99217-6933
509.487.3312
Written permission must be obtained to modify this software.
Permission is granted to copy and use this software, as long
as the code and this header are unmodified.
Exception: the software may be modified to change the values
for the following five variables only:
LayerName
LayerColor
DefaultCurve
NextPointFactor
ZigZagWidth
R. ROBERT BELL PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
R. ROBERT BELL SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.
R. ROBERT BELL DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM
WILL BE UNINTERRUPTED OR ERROR FREE.
RobertB@AcadX.com
********************************************************* ** SUBR **
<edit: by CAB>
Please post a link to the routine & not the code.
