Author Topic: Pop-up Help  (Read 3893 times)
sinc
Pop-up Help
« on: February 15, 2008, 06:20:26 PM »
Has anyone tried implementing pop-up help on .NET forms in Autocad?
I'm trying to get balloons to pop open when the user hovers the mouse over a control, but I'm not sure how to proceed.  I can't get a HelpProvider to work, but from the description, it sounds like I don't even want that style of help, even if I could get it to work.  From the description, it sounds like a HelpProvider expects the user to hit F1 to see any of the pop-up balloons, and that's not what I want.  I'm trying to get balloons to popup automatically, just from a mouse hover.
Re: Pop-up Help
« Reply #1 on: February 15, 2008, 06:38:25 PM »
You need to look at input point monitor.  You can start on this post, and read for a couple of pages.  As far as having a bubble pop up, I never got that to work, and I don't think Glenn posted a solution for that either.
Re: Pop-up Help
« Reply #2 on: February 15, 2008, 07:57:19 PM »
Richard,
do you mean
HelpProvider
or ToolTips
I think sinc is after balloons on the form, not on Acad entities.
Re: Pop-up Help
« Reply #3 on: February 15, 2008, 08:42:29 PM »
Something like ...
using WinForms = System.Windows.Forms;
using FormBalloonTest;
[assembly: AcRx.CommandClass(typeof(kdub.Testing.Commands.TestCommands))]
namespace kdub.Testing.Commands
    /// <summary>
    /// Summary description for TestCommands Class.
    /// </summary>
    public class TestCommands
        public TestCommands()
            // TODO: Add constructor logic here
        [AcRx.CommandMethod("Cmd1")]
        static public void test()
            TestFormForBalloons testForm = new TestFormForBalloons();
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(testForm);
namespace FormBalloonTest
    public partial class TestFormForBalloons : Form
        public TestFormForBalloons()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            this.Close();
        private void TestFormForBalloons_Load(object sender, EventArgs e)
            ToolTip toolTip01 = new ToolTip();
            toolTip01.AutoPopDelay = 4000;
            toolTip01.InitialDelay = 1000;
            toolTip01.ReshowDelay = 500;
            // Force the ToolTip text to display.
            toolTip01.ShowAlways = true;
            // Set up the ToolTip text.
            toolTip01.SetToolTip(this.button1, "Press Me, Press me .... ");
            toolTip01.SetToolTip(this.textBox1, "Add something inane to the textBox");
and the piccy ;
Re: Pop-up Help
« Reply #4 on: February 15, 2008, 09:01:39 PM »
.. and ;
            toolTip01.IsBalloon = true;
            toolTip01.UseAnimation = true;
Re: Pop-up Help
« Reply #5 on: February 15, 2008, 09:11:12 PM »
The zipped Solution is attached, for anyone interested ..
sinc
Re: Pop-up Help
« Reply #6 on: February 15, 2008, 09:37:34 PM »
Perfect!  Thanks, Kerry.  I got off on a wrong tangent trying to deal with that HelpProvider class, and didn't even see the ToolTip one.
MickD
Re: Pop-up Help
« Reply #7 on: February 15, 2008, 09:39:11 PM »
I'm pretty sure that you can add the tooltip in the properties sheet in the form designer too, you could in VB/A from memory, may save some coding time :)
- John Carmack
- J.R.R. Tolkien
sinc
Re: Pop-up Help
« Reply #8 on: February 15, 2008, 09:49:27 PM »
Yes, you can.
Re: Pop-up Help
« Reply #9 on: February 15, 2008, 09:50:27 PM »
I thought so too Mick, but couldn't see it when I went looking ..  ;-) .. but there may be several reasons for that ..
sinc
Re: Pop-up Help
« Reply #10 on: February 15, 2008, 09:52:47 PM »
It's in the Common Controls.
Re: Pop-up Help
« Reply #11 on: February 15, 2008, 09:56:02 PM »
ahhh .. must be added from the Toolbox first ... too obvious :-)
sinc
Re: Pop-up Help
« Reply #12 on: February 16, 2008, 10:30:10 AM »
Well, not exactly obvious.  Why is it in with the Common Controls?  Since this component works in a very similar manner to the HelpProvider class, why isn't the ToolTip in the Component section with HelpProvider and the other components?  It seems to me that this component is mis-categorized.  If it had been in the Components section with the HelpProvider, I would have found it myself.
Although really I probably should have seen it anyway.  After all, I've used a fair number of TextBoxes now, and the TextBox is right next to the ToolTip.
