Author Topic: Inno Setup  (Read 3005 times)
Inno Setup
« on: August 17, 2004, 10:50:56 AM »
I am trying to compile all of my tools into Inno Setup so I can distribute them more easily. My question is.....How do I test for AutoCAD profiles so I can add search paths to each when installing?
Thanks,
Ron
hendie
Inno Setup
« Reply #1 on: August 17, 2004, 11:32:36 AM »
I may be wrong but doesn't Inno setup automatically pick up all the profiles on the target PC and prompt the user to select which profiles to add paths to ?
(you can also specify a completely new profile to use or copy from an existing one)
beware though, if you are adding lines to the Acaddoc.lsp, if one doesn't exist, Inno creates one in the first_support_path it finds ~ which is (one of)the one(s) you just added.
hendie
Inno Setup
« Reply #2 on: August 17, 2004, 11:36:50 AM »
I would also (strongly) suggest downloading a copy of ISTOOL from http://www.istool.org ~ it makes working with Inno so much easier
Re: Inno Setup
« Reply #3 on: August 17, 2004, 11:50:20 AM »
Quote from: ronjonp
Thanks,
Ron
You need AcadInstall from www.cadwerx.net You then use Inno to run acadinstall for all the acad profiles.
hendie
Inno Setup
« Reply #4 on: August 17, 2004, 11:56:38 AM »
sorry... complete brain fart there ~ I was thinking of Acadinstall which Mark has so kindly commented on. that's where you get the profile info  :oops:
but still get Istool though !
Inno Setup
« Reply #5 on: August 17, 2004, 01:07:40 PM »
Thanks guys. This should get me well on my way.  :D  :D
Inno Setup
« Reply #6 on: August 17, 2004, 01:20:31 PM »
Quote from: ronjonp
it's a piece of cake to setup, (pun intended) but if you run into trouble post a question in the vlisp forum.
